robert_smallshire
- Joined
- Nov 11, 2025
- Messages
- 13
I'm aware that the earliest (1983) Microsoft green-eyed mouse came in (at least) two versions:
A Bus Mouse version which used a male DE-9 connector (albeit with pins 1 and 7 omitted) on the mouse cable. This version required a special PC/XT ISA card to provide the interface and was described by Microsoft as "for the IBM PC that either doesn't have a serial communications interface board installed or whose serial communications port is already used for something else". The signals from the mouse were raw quadrature from the encoders.
The second version was a Serial Mouse which used a female DB-25 connector on the mouse cable for use with a standard (at the time) RS-232 port with a male connector on the PC. The Microsoft documentation says, "Serial version packages include the mouse pointing unit, a connecting cable, and a 25-pin female connector."
Sadly, there is so much confusion about early mouse connectors, and so many sellers inadvertently mislabelling that it's relatively difficult to find reliable information. Much of the confusion is caused by misidentification of the DE-9 bus mouse connector as a 9-pin serial connector. Of course, eventually DE-9 mouse connectors did eventually became common, but for serial mice, and with female gender on the mouse cable. Microsoft eventually retired DE-9 male bus mouse connector in favour of the Mini-DIN-9 InPort connector and interface board in 1986.
Having finally got this picture clear in my head, my understanding of the story has been confounded by finding pictures of green-eyed mouses with DB-25 *male* connectors.
This is a real surprise, not consistent with the documentation, and not consistent with PC serial ports having male gender. At first I thought the connectors may have been changed, but all the examples I've found have Microsoft-branded DB-25 male connectors, although some only have the necessary pins, not the full complement of 25.
What's the story here? Are these aftermarket modifications, or different product versions or product revisions?
