glitch
So we found a MINC-23 at the MIT Flea (full album: http://imgur.com/a/Hov9T#0 ):
Came with what you see (MINC-23 chassis + RX02), a VT-105, and a pile of cables! It was used at the Mount Washington Observatory, most likely taking inputs from various bits of weather-monitoring equipment. The folks from the observatory have a pile of manuals and documentation and, as luck would have it, will be in Troy on Friday anyway.
Unfortunately, it appears to have had a family of mice in it at some point, as you can see from the "before the cleaning" and "in the card cage" pictures. Lots of mouse filth. The cards cleaned up OK, but I haven't extracted/cleaned the backplane yet, which is where the real filth is. It appears to have oozed down through the backplane and out of the bottom of the MINC case, so I'm sure that will be *real* pleasant to get clean. Hopefully it's not ruined.
I pulled the cards tonight and cleaned the mouse filth off, couldn't have been there too long because it came off with hot water, dish soap and a tooth brush with little scrubbing. There was very minimal corrosion, mostly at the point where the tin traces became gold edge fingers. I dug out my 11/03 chassis and tested the CPU, RAM and DLV-11J which all appear to work. The RAM (64 KW/128 KB parity MOS) was one of the filthier boards, so that's promising!
