Good evening all. Been lurking around here in the back ground off & on for a few years. Mostly enjoy reading and learing about various systems. Not a stranger to vintage computing, and have acquired machines that I wanted when I was growing up. I am an IBM & Commodore guy, and up to now knew almost nothing about the TRS80 family.
First the backstory: Over a year and a half ago I scored a TRS80 Model 1 off Ebay. Suffice it to say it was nearly all but destroyed between the horrible pack job and UPS. Seller apologized profusely and issued full refund. Tossed it, still the boxes, in the corner. About 4 weeks ago I almost put it in the recycling bin. Decided against it for various reasons, and proceded down the rabbit hole.
Keyboard plastic was easily in a 100 pcs. Monitor case severly cracked in several places. But no damage to any of the internals, or the keyboard save for one missing key (funny how the gaping hole in the box did not allow any broken plastic to escape!) Expansion unit was unscathed. Of the 3 drives, only one broken latch. No software or manuals included.
PS voltages checked out OK, so I fired it up...and nothing but scramble screen. After 30 minutes of cleaning contacts and reseating chips the darn thing came to life! Played around with it for an hour or more, absolutely no issues, even a rock solid stable display. I was floored. Have not hooked up EI or drives yet. As Bob said, baby steps.
The problem came after I cleaned the circuit board and replaced keyboard cable. A very strange vertical sync problem. It has situated the top of the display area near bottom of screen. Done a lot of reading and watched several videos, but nothing I have found addresses this type of issue. I do have the tech ref manual, and have done some preliminary troubleshooting. Some things check out, some don't or just not sure. Just wanted to get some ideas before I start replacing the usual suspect chips.
Also, is it possible issue could be the monitor itself?
