sanchezman
So I recently had the incredibly good fortune to pick up a TRS-80, Model I, level II computer with manuals, cassette programs, and accessories for just $2 at a local electronics swap meet.
Everything about the computer works well. Everything, that is, except for the 'e' key. Pressing it does not register anything. I know that it is a problem with the switch inside, because by shorting the solder contacts behind the key, I can make the computer recognize a keypress. Incidentally, the 's' key also registers two presses for each time I press it, but that is easily remedied by deleting one of the s's.
Anyway, I was looking to examine the switch beneath the key to repair/replace it, but the switches are sandwiched between a metal plate and the circuit board. How can I get to the key in order to fix it? My electronic skills stop at crude soldering (and I lack a soldering iron), so if anything more than unscrewing/detaching is required, I will not be able to do it. If such steps are required, is there somebody in the United States who offers such services for a reasonable price?
It is a shame that such a wonderful unit is rendered virtually unusable because one of the most used letters in the English language is unavailable. I can't even make a simple program, because RETURN (RET.) requires the letter E.
Thanks in advance for any and all help.
