As I understand it modems and VoIP don't really work. I assume most people have tried SIP is MGCP and h323 the same?
I had a look around for BRI 64K over IP and found TDM over IP, So, T1 or E1 over IP. For those that are not up-to-speed, Back in the '60s the telephone network was digitized using T1 or E1 (in Europe) to save on trunk lines. You take one pair, and run 24(23 usable) channels over it. Massive cost savings, however it also creates a maximum of 64Kb/s digital stream, or max 56Kb/s (analogue-to-digital) stream. As such all modem standards running on a dial up line can be represented in that 64Kb/s.
I'm interested in the later >33k standards too, that need to be terminated over T1/E1. whatever 56Kb/s standard you use, two 56k modems wont talk to each other at 56k, only 33k. The other end of a 56K modem needs a Digital Modem, that is on the end of the 64Kb/s data stream. As I (struggle to) understand this, the digital modem is kinda like a PC with a sound card input from S/PDIF, it reads and writes directly to the PCM signal.
Please tell me about your experiences with modems and VoIP.
