Gary C
After putting a cheeky bid on a Commodore monitor with a free Amiga 500 thrown in (seriously the price was so cheap, the Amiga could be called a free gift) I then realised it wasn't in a place nearby, but near Bridlington on the east coast and I live on the west coast. Ah well, even with the 300 mile round trip it was still cheap.
Put on one of the museums machines to replace a wonky monitor and all looks good
So the Acorn version of the phillips CM8833 now on the bench and everything looks ok, but no blue or green.
Now the issue. The Acorn and the Commodore have male 9 pin D plugs on them and they are now obviously wired different.
With a male plug, pin 5 of the plug connects to what is labelled pin 1 on the PCB, pin 4 to 2 and pin 3 to 3. How very odd
This is from above and matches the silkscreen of my monitor, and if you present a male 90 degree D, you can plainly see it doesn't match !
Obviously Acorn used a different pinout to Commodore even though they both used a cable with a female into a male socket on the monitor.
What a pain, as they should be a universal monitor !
This is from above and matches the silkscreen of my monitor, and if you present a male 90 degree D, you can plainly see it doesn't match !Obviously Acorn used a different pinout to Commodore even though they both used a cable with a female into a male socket on the monitor.
