I have an MB-1433150UCV-E motherboard I am trying to get working and am trying to figure out how best to proceed. Any help would be appreciated.
The issue is with the rtc - battery state low. Perhaps this is a basic question but can I simply insert a 3 volt holder and battery or will I need to replace the rtc? I have read different posts about replacing the rtc and that is not a problem if it is the only solution.
In the empty space where there is usually a battery it says
int rtc: 1-2
ext rtc: 2-3
I don't see an rtc labeled jumper. I also can't locate jp8 which seems to be referenced in the setup files linked below.
I would assume the int. is the current installed rtc. As a third battery option, there seems to be placement with three solder points for an external battery pack.
can easily get 3v battery and holder... hoping it will possibly be a solution but not sure.
have found
https://www.philscomputerlab.com/biostar-mb-1433.html
and
https://www.elhvb.com/webhq/models/486vlb3/mb1433uc.html
but the link to the actual manual is not working.
Suggestions or experience very much appreciated! thanks.
int rtc: 1-2
ext rtc: 2-3
have found
and
