Motherboard Identification
ASUS 5IS. Not sure about a manual.
Edit: Azza 5IS, not ASUS
Perfect, thanks.
If you look in the manual you’ll see two rows for the speaker and power LED. That section is horizontal as compared to the other front panel stuff, according to the manual. Well, I plugged in the speaker and power LED cables and got nothing.
SBXXX
PBXXX
The black wires for each of these would intuitively go right next to the colored ones (pin 2 on each row), but when that didn’t work, I put the colored pins both on pin 1 on their respective rows, then the speaker black wire on pin 3 and the PLED on pin 4. Then it worked.
SXBXX
PXXBX
What gives?
I would speculate that the original connector was five positions with only those wires populated in the connector. I have several like that. But like caluser2000 said, if it works it works!
