mc68010
These are pretty cool. They were small single board computers for learning to program 68000 cpu from 1981. Has a very neat built in monitor and debugger called Tutor you can access with a serial terminal. You can read all about it in the manual on bitsavers http://bitsavers.trailing-edge.com/pdf/motorola/68000/versados/MEX68KECB_D2_EduCompBd_Jul82.pdf
The serial cable is easy to make if you get the ribbon cable press on style connectors for both the edge card and DB25 ends. It's wired so you just line up pin 1 on both ends.
Requires a power supply with +5v +12v and -12v which is just about most power supplies having anything to do with computers.
Asking $75 with free shipping in the US.
