Christoffer
I got this for next to nothing yesturday, in working order. sortof.
It's a Motorola trainer for the 6802 processor, datecoded late '81, but the design looks more 70's-ish, so I guess it could be older.
It's a standard trainer, with HEX 7seg displays for data/address and a hex+function keypad. It features a "wrap area" for wire-wrapping your own additions, and a massive expansion connector on the back of it. It has a 6832 PIA broken out to a DIP socket for the user to use, and one for keypad/display stuff. The keypad is interrupt driven, by the way.
It has a small monitor in ROM, allowing you to punch in and run assembler code, review/set registers, set breakpoints in your program, and save/load to/from cassette.
Mine came in a very homemade aluminum case, with aclear plexiglas front (sorry for the screenglare) - complete with 220V psu.
This turned out to be less-than-ideal, since the transformer is putting out a bit more than the manual reccomends- almost 9V more, actually. The poor 7805 in a TO-3 case gets pretty hot pretty fast, but I plan to make an external 5V supply.
What makes this trainer very interesting, is that it's designed for almost limitless expansion. The card-edge connector on the back is compatible with the Motorola EXORCISER system, allowing this board to be used as a processor board for a such system, with the possibility of adding more boards to the backplane, like floppy or hard-disk controller, more RAM, and more!
The standard config is the one I have, but the board has room for a lot more. It's explained nicely in the manual, too. Under the keypad (I guess you won't need it, then, or you'd put it on a ribbon cable) is room for a MC14411 baudrate generator and the classic MC6850 ACIA serial controller, as well as RS-232 line drivers and a DSUB-25 connector, allowing it to talk with a terminal!
It has an empty ROM socket, where I believe you can put the Motorola "JBUG" rom. I don't know if that's required to run any meaningful serial comms, or it's present in the current "d5BUG" rom. Don't even know the difference, really.
Attached is a photo. I hope others has this machine too and has more knowledge/info
--Christoffer
--Christoffer
