smbaker
I have a couple MPI BR8B2A drives with issues. On both of them I performed a test by writing an image to it and then reading back the image. Screenshots are attached. I'm assuming from this that one drive has one bad head and the other has two bad heads. Am I interpreting that correctly?
The one with two bad heads "sounds bad" while it is spinning. I'm not sure exactly how to describe the sound, but it does not sound smooth, so potentially it's not a case of bad heads but a case of the disk not spinning at a consistent speed. I have disassembled it and I find no play in the bearings.
Are there any particular known issues with MPI drives and their heads?
