Hi,
Once again, a new version of mTCP is available at http://www.brutman.com/mTCP .
On the surface this version looks like the prior versions. The biggest visible change is that FTP now has command line editing and recall, which makes it much nicer to use.
Deeper down in the TCP/IP stack the changes were pretty significant. This is the first version to support IP fragment reassembly. I have been able to get by without it for the last two years but really to be a compliant TCP/IP stack it should support sending and receiving IP fragments. This change will improve the compatibility with other networks and gateways. I was able to get IP fragmentation support in with minimal performance impact; you'll only notice it if you get fragmented packets.
For those of you not using mTCP yet, it includes a DHCP client, FTP, IRC, Telnet, Ping, SNTP and Netcat. It runs on just about any (Free)DOS machine (virtual or otherwise) that you can find.
Regards,
Mike
Regards,
Mike
