powermac:simh peter$ ./BIN/pdp11
Mar 30 21:17:02 pdp11[12140] <Warning>: CGSConnectionByID: 0 is not a valid connection ID.
Mar 30 21:17:02 pdp11[12140] <Warning>: Invalid Connection ID 0
2018-03-30 21:17:02.802 pdp11[12140:308452] 21:17:02.802 WARNING: 140: This application, or a library it uses, is using the deprecated Carbon Component Manager for hosting Audio Units. Support for this will be removed in a future release. Also, this makes the host incompatible with version 3 audio units. Please transition to the API's in AudioComponent.h.
PDP-11 simulator V4.0-0 Current git commit id: 2051422e
sim>
sim> set rl rl02
sim> set rq0 rd54
sim> attach rl0 rl057.dsk
sim> attach rq0 du057.dsk
RQ0: creating new file
sim> boot rl0
RT-11FB V05.07
.TYPE V5USER.TXT
RT-11 V5.7
Installation of RT-11 Version 5.7 is complete and you are now running
RT-11 from your system volume.
Your system volume is your working volume if you have used the Automatic
Installation (AI) procedure. If you have installed RT-11 using that
procedure, Mentec recommends you verify the correct operation of your
system's software using the VERIFY verification procedure. You can only
perform VERIFY on the valid target (output) media you used for the AI
procedure. Run VERIFY before you run CONFIG. To run VERIFY, enter the
command:
IND VERIFY
Mentec recommends you read the file V5NOTE.TXT, which you can TYPE or
PRINT. Also, read the Introduction to RT-11, rewritten for V5.7, which
contains much of the information you need to use RT-11 Version 5.7.
.R MSCPCK
?MSCPCK-I-MU0-TK50 FW Rev Level is 005/HW Rev Level is 001
?MSCPCK-W-TQK50 controller below FW Rev 4/HW Rev 6
.dir
.ini du:
DU0:/Initialize; Are you sure? Y
.copy/system dl: du:
Files copied:
DL:STRTAI.COM to DU:STRTAI.COM
DL:STRTFB.COM to DU:STRTFB.COM
DL:STRTSB.COM to DU:STRTSB.COM
DL:STRTXM.COM to DU:STRTXM.COM
DL:STRTXB.COM to DU:STRTXB.COM
DL:STRTZM.COM to DU:STRTZM.COM
DL:STRTZB.COM to DU:STRTZB.COM
DL:PIP.SAV to DU:PIP.SAV
DL:DUP.SAV to DU:DUP.SAV
DL:DIR.SAV to DU:DIR.SAV
DL:IND.SAV to DU:IND.SAV
DL:RESORC.SAV to DU:RESORC.SAV
DL:EDIT.SAV to DU:EDIT.SAV
DL:KED.SAV to DU:KED.SAV
DL:KEX.SAV to DU:KEX.SAV
DL:MACRO.SAV to DU:MACRO.SAV
DL:CREF.SAV to DU:CREF.SAV
DL:LINK.SAV to DU:LINK.SAV
DL:MONMRG.SAV to DU:MONMRG.SAV
DL:LIBR.SAV to DU:LIBR.SAV
DL:FILEX.SAV to DU:FILEX.SAV
DL:SRCCOM.SAV to DU:SRCCOM.SAV
DL:BINCOM.SAV to DU:BINCOM.SAV
DL:SLP.SAV to DU:SLP.SAV
DL:DUMP.SAV to DU:DUMP.SAV
DL:SIPP.SAV to DU:SIPP.SAV
DL:BUP.SAV to DU:BUP.SAV
DL:PAT.SAV to DU:PAT.SAV
DL:HELP.SAV to DU:HELP.SAV
DL:SYSMAC.SML to DU:SYSMAC.SML
DL:SYSLIB.OBJ to DU:SYSLIB.OBJ
DL:BATCH.SAV to DU:BATCH.SAV
DL:QUEMAN.SAV to DU:QUEMAN.SAV
DL:FORMAT.SAV to DU:FORMAT.SAV
DL:SETUP.SAV to DU:SETUP.SAV
DL:VTCOM.SAV to DU:VTCOM.SAV
DL:DATIME.SAV to DU:DATIME.SAV
DL:DATIME.MAC to DU:DATIME.MAC
DL:DATIME.COM to DU:DATIME.COM
DL:LET.SAV to DU:LET.SAV
DL:SPLIT.SAV to DU:SPLIT.SAV
DL:UCL.SAV to DU:UCL.SAV
DL:VBGEXE.SAV to DU:VBGEXE.SAV
DL:TERMID.SAV to DU:TERMID.SAV
DL:QUEUE.REL to DU:QUEUE.REL
DL:RTMON.REL to DU:RTMON.REL
DL:SPOOL.REL to DU:SPOOL.REL
DL:SPOOL.SAV to DU:SPOOL.SAV
DL:VTCOM.REL to DU:VTCOM.REL
DL:TRANSF.SAV to DU:TRANSF.SAV
DL:TRANSF.TSK to DU:TRANSF.TSK
DL:TRANSF.EXE to DU:TRANSF.EXE
DL:GIDIS.SAV to DU:GIDIS.SAV
DL:ALPH00.FNT to DU:ALPH00.FNT
DL:ODT.OBJ to DU:ODT.OBJ
DL:VDT.OBJ to DU:VDT.OBJ
DL:MDUP.SAV to DU:MDUP.SAV
DL:MBOOT.BOT to DU:MBOOT.BOT
DL:MBOT16.BOT to DU:MBOT16.BOT
DL:MSBOOT.BOT to DU:MSBOOT.BOT
DL:MDUP.AI to DU:MDUP.AI
DL:MDUP.MM to DU:MDUP.MM
DL:MDUP.MS to DU:MDUP.MS
DL:MDUP.MT to DU:MDUP.MT
DL:MDUP.MU to DU:MDUP.MU
DL:DEMOBG.MAC to DU:DEMOBG.MAC
DL:DEMOFG.MAC to DU:DEMOFG.MAC
DL:DEMOF1.FOR to DU:DEMOF1.FOR
DL:DEMOF2.FOR to DU:DEMOF2.FOR
DL:DEMOF3.FOR to DU:DEMOF3.FOR
DL:DEMOB1.BAS to DU:DEMOB1.BAS
DL:DEMOM1.MAC to DU:DEMOM1.MAC
DL:DEMOKD.TXT to DU:DEMOKD.TXT
DL:VERIFY.COM to DU:VERIFY.COM
DL:IVP.COM to DU:IVP.COM
DL:IVP.MAC to DU:IVP.MAC
DL:MTB.COM to DU:MTB.COM
DL:MSB.COM to DU:MSB.COM
DL:MS1B.COM to DU:MS1B.COM
DL:MUB.COM to DU:MUB.COM
DL:FB.MAC to DU:FB.MAC
DL:SB.MAC to DU:SB.MAC
DL:XB.MAC to DU:XB.MAC
DL:XM.MAC to DU:XM.MAC
DL:ZB.MAC to DU:ZB.MAC
DL:ZM.MAC to DU:ZM.MAC
DL:SYSTEM.MLB to DU:SYSTEM.MLB
DL:EDTL.MLB to DU:EDTL.MLB
DL:BSTRAP.MAC to DU:BSTRAP.MAC
DL:EDTG.MAC to DU:EDTG.MAC
DL:KMON.MAC to DU:KMON.MAC
DL:KMOVLY.MAC to DU:KMOVLY.MAC
DL:MTTEMT.MAC to DU:MTTEMT.MAC
DL:MTTINT.MAC to DU:MTTINT.MAC
DL:RMON.MAC to DU:RMON.MAC
DL:TRMTBL.MAC to DU:TRMTBL.MAC
DL:USR.MAC to DU:USR.MAC
DL:XMSUBS.MAC to DU:XMSUBS.MAC
DL:BA.MAC to DU:BA.MAC
DL:DL.MAC to DU:DL.MAC
DL:DM.MAC to DU:DM.MAC
DL:DU.MAC to DU:DU.MAC
DL:DW.MAC to DU:DW.MAC
DL:DX.MAC to DU:DX.MAC
DL:DY.MAC to DU:DY.MAC
DL:DZ.MAC to DU:DZ.MAC
DL:LD.MAC to DU:LD.MAC
DL:LP.MAC to DU:LP.MAC
DL:LS.MAC to DU:LS.MAC
DL:NC.MAC to DU:NC.MAC
DL:NI.MAC to DU:NI.MAC
DL:NL.MAC to DU:NL.MAC
DL:NQ.MAC to DU:NQ.MAC
DL:NU.MAC to DU:NU.MAC
DL:RK.MAC to DU:RK.MAC
DL:SP.MAC to DU:SP.MAC
DL:TJ.MAC to DU:TJ.MAC
DL:TM.MAC to DU:TM.MAC
DL:TS.MAC to DU:TS.MAC
DL:TU.MAC to DU:TU.MAC
DL:UM.MAC to DU:UM.MAC
DL:VM.MAC to DU:VM.MAC
DL:XC.MAC to DU:XC.MAC
DL:XL.MAC to DU:XL.MAC
DL:FSM.MAC to DU:FSM.MAC
DL:EL.MAC to DU:EL.MAC
DL:ERROUT.SAV to DU:ERROUT.SAV
DL:ELCOPY.MAC to DU:ELCOPY.MAC
DL:ELINIT.MAC to DU:ELINIT.MAC
DL:ELTASK.MAC to DU:ELTASK.MAC
DL:ERRTXT.MAC to DU:ERRTXT.MAC
DL:ERROUT.OBJ to DU:ERROUT.OBJ
DL:RTSB.MAP to DU:RTSB.MAP
DL:RTFB.MAP to DU:RTFB.MAP
DL:RTXM.MAP to DU:RTXM.MAP
DL:RTZM.MAP to DU:RTZM.MAP
DL:SYSGEN.COM to DU:SYSGEN.COM
DL:SBFB.ANS to DU:SBFB.ANS
DL:XBXM.ANS to DU:XBXM.ANS
DL:XMEL.ANS to DU:XMEL.ANS
DL:ZBZM.ANS to DU:ZBZM.ANS
DL:CONFIG.COM to DU:CONFIG.COM
DL:CONFIG.SAV to DU:CONFIG.SAV
DL:V5USER.TXT to DU:V5USER.TXT
DL:V5NOTE.TXT to DU:V5NOTE.TXT
DL:CUSTOM.TXT to DU:CUSTOM.TXT
DL:CONSOL.MAC to DU:CONSOL.MAC
DL:NITEST.MAC to DU:NITEST.MAC
DL:MSCPCK.SAV to DU:MSCPCK.SAV
DL:DBGSYM.SAV to DU:DBGSYM.SAV
DL:INDEX.SAV to DU:INDEX.SAV
DL:INDEXX.SAV to DU:INDEXX.SAV
DL:INDEXA.IMG to DU:INDEXA.IMG
DL:INDEXB.IMG to DU:INDEXB.IMG
DL:INDEX.IDX to DU:INDEX.IDX
DL:TECO.SAV to DU:TECO.SAV
DL:CR.MAC to DU:CR.MAC
DL:CT.MAC to DU:CT.MAC
DL:DD.MAC to DU:DD.MAC
DL:DP.MAC to DU:DP.MAC
DL:DS.MAC to DU:DS.MAC
DL:DT.MAC to DU:DT.MAC
DL:PC.MAC to DU:PC.MAC
DL:PD.MAC to DU:PD.MAC
DL:RF.MAC to DU:RF.MAC
DL:SWAP.SYS to DU:SWAP.SYS
DL:RT11AI.SYS to DU:RT11AI.SYS
DL:RT11SB.SYS to DU:RT11SB.SYS
DL:RT11FB.SYS to DU:RT11FB.SYS
DL:RT11XM.SYS to DU:RT11XM.SYS
DL:RT11ZM.SYS to DU:RT11ZM.SYS
DL:DL.SYS to DU:DL.SYS
DL:DM.SYS to DU:DM.SYS
DL:DU.SYS to DU:DU.SYS
DL:DW.SYS to DU:DW.SYS
DL:DX.SYS to DU:DX.SYS
DL:DY.SYS to DU:DY.SYS
DL:DZ.SYS to DU:DZ.SYS
DL:RK.SYS to DU:RK.SYS
DL:LD.SYS to DU:LD.SYS
DL:LP.SYS to DU:LP.SYS
DL:LS.SYS to DU:LS.SYS
DL:MM.SYS to DU:MM.SYS
DL:MS.SYS to DU:MS.SYS
DL:MT.SYS to DU:MT.SYS
DL:MU.SYS to DU:MU.SYS
DL:NL.SYS to DU:NL.SYS
DL:PI.SYS to DU:PI.SYS
DL:SL.SYS to DU:SL.SYS
DL:SLMIN.SYS to DU:SLMIN.SYS
DL:SP.SYS to DU:SP.SYS
DL:VM.SYS to DU:VM.SYS
DL:XC.SYS to DU:XC.SYS
DL:XL.SYS to DU:XL.SYS
DL:DLX.SYS to DU:DLX.SYS
DL:DMX.SYS to DU:DMX.SYS
DL:DUX.SYS to DU:DUX.SYS
DL:DWX.SYS to DU:DWX.SYS
DL:DXX.SYS to DU:DXX.SYS
DL:DYX.SYS to DU:DYX.SYS
DL:DZX.SYS to DU:DZX.SYS
DL:LDX.SYS to DU:LDX.SYS
DL:LPX.SYS to DU:LPX.SYS
DL:LSX.SYS to DU:LSX.SYS
DL:MMX.SYS to DU:MMX.SYS
DL:MSX.SYS to DU:MSX.SYS
DL:MTX.SYS to DU:MTX.SYS
DL:MUX.SYS to DU:MUX.SYS
DL:NCX.SYS to DU:NCX.SYS
DL:NLX.SYS to DU:NLX.SYS
DL:NQX.SYS to DU:NQX.SYS
DL:NUX.SYS to DU:NUX.SYS
DL:PIX.SYS to DU:PIX.SYS
DL:RKX.SYS to DU:RKX.SYS
DL:SLX.SYS to DU:SLX.SYS
DL:SPX.SYS to DU:SPX.SYS
DL:UBX.SYS to DU:UBX.SYS
DL:VMX.SYS to DU:VMX.SYS
DL:XCX.SYS to DU:XCX.SYS
DL:XLX.SYS to DU:XLX.SYS
DL:SDS.SYS to DU:SDS.SYS
DL:SDH.SYS to DU:SDH.SYS
DL:SDSX.SYS to DU:SDSX.SYS
DL:SDHX.SYS to DU:SDHX.SYS
.copy/boot:du du:rt11fb.sys
To ? du:
Simulation stopped, PC: 151722 (BR 151706)
sim> boot rq0
RT-11FB V05.07
.TYPE V5USER.TXT
RT-11 V5.7
command:
IND VERIFY
.R MSCPCK
