My KDJ11-B
Hunta
Samara, Russian Federation
Currently with FPA and 24 MHz Quartz
Some info and speed test
Testing in progress - Please wait
Memory Size is 4088 K Bytes
9 Step memory test
Step 1 2 3 4 5 6 7 8 9
Message 04 Entering Dialog mode
Commands are Help, Boot, List, Setup, Map and Test.
Type a command then press the RETURN key: LIST
Device Unit
name numbers Source Device type
DU 0-255 CPU ROM RDnn, RXnn, RC25, RAnn
DL 0-3 CPU ROM RL01, RL02
DX 0-1 CPU ROM RX01
DY 0-1 CPU ROM RX02
DD 0-1 CPU ROM TU58
DK 0-7 CPU ROM RK05
MU 0-255 CPU ROM TK50, TU81
MS 0-3 CPU ROM TK25, TS05
ZA 0-64 CPU ROM CF 161000
ZB 0-64 CPU ROM CF 161040
ZC 0-64 CPU ROM CF 161100
ZD 0-64 CPU ROM CF 161140
ZE 0-64 CPU ROM CF 161200
ZF 0-64 CPU ROM CF 161240
WQ 0-64 CPU ROM CF 177120 primary
Press the RETURN key when ready to continue
Device Unit
WS 0-64 CPU ROM CF 177120 slave
XH 0-1 CPU ROM DECNET ETHERNET
NU 0-15 CPU ROM DECNET DUV11
NE 0-15 CPU ROM DECNET DLV11-E
NF 0-15 CPU ROM DECNET DLV11-F
Type a command then press the RETURN key: MAP
23.996 MHz
CPU Options: FPA
Memory Map
Starting Ending Size in CSR CSR Bus
Address address K Bytes address type type
00000000 - 17757776 4088 17772102 Parity PMI
I/O page Map
Starting Ending
Address address
17761000 - 17761176
17765000 - 17765776 CPU ROM or EEPROM
17770200 - 17770376 Unibus Map
17772102 Memory CSR
17772150 - 17772152
17772200 - 17772276 Supervisor I and D PDR/PAR's
17772300 - 17772376 Kernel I and D PDR/PAR's
17772516 MMR3
17773000 - 17773776 CPU ROM
17776540 - 17776546
17777400 - 17777416
17777520 - 17777524 BCSR, PCR, BCR/BDR
17777546 Clock CSR
17777560 - 17777566 Console SLU
17777572 - 17777576 MMR0,1,2
17777600 - 17777676 User I and D PDR/PAR's
17777744 - 17777752 MSER, CCR, MREG, Hit/Miss
I/O page Map
Starting Ending
Address address
17777766 CPU Error
17777772 PIRQ
17777776 PSW
Type a command then press the RETURN key: BOO ZB1
Trying ZB1
Starting system from ZB1
RT-11SB (S) V05.07
.R MSCPCK
.SHO CONF
RT-11SB (S) V05.07
Booted from ZB1:RT11SB
USR is set SWAP
EXIT is set SWAP
KMON is set NOIND
MODE is set NOSJ
TT is set NOQUIET
ERROR is set ERROR
SL is set OFF
EDIT is set KED
FORTRAN is set FORTRA
KMON nesting depth is 3
Global .SCCA flag is disabled
CLI is set DCL, CCL, UCL, NO UCF
PDP 11/83 Processor
4088KB of memory
Floating Point Accelerator Unit
Extended Instruction Set (EIS)
Memory Management Unit
Parity Memory
Cache Memory
PMI Memory
50 Hertz System Clock
Memory parity support
SB timer support
Global .SCCA support
FPU support
Extended unit support
.RUN HX7:SPEED4
Speed test (Performance test, with enabled, if found, cache)
R0(23456.)+R0(12345.) empty 1 468 793 ops/s
R1(23456.)+R0(12345.) 1 179 518 ops/s -> 5 988 999 ops/s
R1(23456.)+@R0(M-12345.) empty 1 468 793 ops/s
R1(23456.)+@R0(M-12345.) 846 203 ops/s -> 1 996 333 ops/s
11.*12. empty 1 468 794 ops/s
11.*12. 229 661 ops/s -> 272 226 ops/s
R2-R3(34567.)/R1(321.) empty 1 179 518 ops/s
R2-R3(34567.)/R1(321.) 153 245 ops/s -> 176 127 ops/s
34567./321. (FPU) empty 248 732 ops/s
34567./321. (FPU) 130 057 ops/s -> 272 587 ops/s
34567.89022+32109.754321 empty 199 112 ops/s
34567.89022+32109.754321 175 741 ops/s -> 1 497 246 ops/s
34567.89022*32109.754321 empty 199 112 ops/s
34567.89022*32109.754321 175 741 ops/s -> 1 497 246 ops/s
34567.89022/32109.754321 empty 199 112 ops/s
34567.89022/32109.754321 155 286 ops/s -> 705 501 ops/s
MOV 8 word 1 empty 986 582 ops/s
MOV 8 word 1 56 910 ops/s -> 60 393 ops/s
MOV 8 word 2 empty 985 348 ops/s
MOV 8 word 2 70 249 ops/s -> 75 641 ops/s
R1 := M(word) 1 470 600 ops/s
R1 := M(even byte) 1 468 793 ops/s
R1 := M(odd byte) 1 468 793 ops/s
CLR R0 - SOB R0, . empty 643 043 ops/s
CLR R0 - SOB R0, . 18 ops/s -> 18 ops/s
153264
@173000G
9 Step memory test
Type a command then press the RETURN key: BOO ZD32
Trying ZD32
Starting system from ZD32
RSX-11M-PLUS V4.6 BL87 2044.KW System:"KXX03 "
>RED ZD1:=SY:
>RED ZD1:=LB:
>RED ZD1:=SP:
>MOU ZD1:"RSX11MPBL87"
>@ZD1:[1,2]STARTUP
>; PLEASE NOTE
>; If you have not yet read the system release notes, please do so
>; now before attempting to perform a SYSGEN or to utilize the new
>; features of this system.
>* Please enter time and date (HH:MM DD-MMM-YYYY) [S]: ^Z
>@ <EOF>
>CON ONL ALL
>DEV
VF0: Offline Loaded Type=unknown
VF1: Offline Loaded Type=unknown
VF2: Offline Loaded Type=unknown
VF3: Offline Loaded Type=unknown
VF4: Offline Loaded Type=unknown
VF5: Offline Loaded Type=unknown
VF6: Offline Loaded Type=unknown
VF7: Offline Loaded Type=unknown
VF10: Offline Loaded Type=unknown
VF11: Offline Loaded Type=unknown
VF12: Offline Loaded Type=unknown
VF13: Offline Loaded Type=unknown
VF14: Offline Loaded Type=unknown
VF15: Offline Loaded Type=unknown
VF16: Offline Loaded Type=unknown
VF17: Offline Loaded Type=unknown
TT0: [1,54] [1,54] - Logged in Loaded
TT1: Offline Loaded
TT2: Offline Loaded
TT3: Loaded
TT4: Offline Loaded
TT5: Offline Loaded
TT6: Offline Loaded
TT7: Offline Loaded
TT10: Offline Loaded
TT11: Offline Loaded
TT12: Offline Loaded
TT13: Offline Loaded
VT0: Loaded
RD0: Loaded
DU0: Loaded Type=RA81
DU1: Loaded Type=RA81
DU2: Offline Loaded Type=unknown
DU3: Offline Loaded Type=unknown
DU4: Offline Loaded Type=unknown
DU5: Offline Loaded Type=unknown
DU6: Offline Loaded Type=unknown
DU7: Offline Loaded Type=unknown
NL0: Loaded
ZA0: Loaded Type=UNKN
ZA1: Loaded Type=UNKN
ZA2: Loaded Type=UNKN
ZA3: Loaded Type=UNKN
ZA4: Offline Loaded Type=unknown
ZA5: Offline Loaded Type=unknown
ZA6: Offline Loaded Type=unknown
ZA7: Offline Loaded Type=unknown
ZA10: Offline Loaded Type=unknown
ZA11: Offline Loaded Type=unknown
ZB0: Loaded Type=UNKN
ZB1: Loaded Type=UNKN
ZB2: Loaded Type=UNKN
ZB3: Loaded Type=UNKN
ZB4: Offline Loaded Type=unknown
ZB5: Offline Loaded Type=unknown
ZB6: Offline Loaded Type=unknown
ZB7: Offline Loaded Type=unknown
ZB10: Offline Loaded Type=unknown
ZB11: Offline Loaded Type=unknown
ZC0: Loaded Type=UNKN
ZC1: Loaded Type=UNKN
ZC2: Loaded Type=UNKN
ZC3: Loaded Type=UNKN
ZC4: Loaded Type=UNKN
ZC5: Loaded Type=UNKN
ZC6: Loaded Type=UNKN
ZC7: Loaded Type=UNKN
ZC10: Loaded Type=UNKN
ZC11: Loaded Type=UNKN
ZD0: Loaded Type=UNKN
ZD1: Public Mounted Loaded Label=RSX11MPBL87 Type=UNKN
ZD2: Loaded Type=UNKN
ZD3: Loaded Type=UNKN
ZD4: Loaded Type=UNKN
ZD5: Loaded Type=UNKN
ZD6: Loaded Type=UNKN
ZD7: Loaded Type=UNKN
ZD10: Loaded Type=UNKN
ZD11: Loaded Type=UNKN
TI0:
CO0: TT0:
CL0: TT0:
SP0: ZD1:
LB0: ZD1:
SY0: ZD1:
>MOU ZC1:/OVR
>BOO ZC1:[1,54]
RSX-11M-PLUS V4.6 BL87 2044.KW System:"KXX002"
>RED ZC1:=SY:
>RED ZC1:=LB:
>RED ZC1:=SP:
>MOU ZC1:"RSX11MPBL87"
>@ZC1:[1,2]STARTUP
>; PLEASE NOTE
>* Please enter time and date (HH:MM DD-MMM-YYYY) [S]: 20:43 17-APR-2021
>TIME 20:43 17-APR-2021
>ACS SY:/BLKS=1024.
>CON ONLINE ALL
>ELI /LOG/LIM
>CLI /INIT=DCL/CTRLC/DPR="<15><12>/$ /"
>INS LB:[1,1]RMSRESAB.TSK/RON=YES/PAR=GEN
>INS LB:[1,1]RMSLBL.TSK/RON=YES/PAR=GEN
>INS LB:[1,1]RMSLBM.TSK/RON=YES/PAR=GEN
>INS $QMGCLI
>INS $QMGCLI/TASK=...PRI
>INS $QMGCLI/TASK=...SUB
>QUE /START:QMG
>INS $QMGPRT/TASK=PRT.../SLV=NO
>QUE LP0:/CR/NM
>START/ACCOUNTING
>CON ESTAT LP0:
>QUE BAP0:/BATCH
>QUE BAP0:/AS:BATCH
>SET /EBC=TI:
>VCP CONNECT LB:[DISKS]UTILS.DSK=VF0:
VCP - Device VF0: has been assigned.
>MOU VF0:UTILS/PUB
>ASN VF0:=LB1:/GBL
>REM ...CA.
>INS LB1:[4,54]CCLRES.TSK/TASK=...CA.
>INS LB1:[4,54]CCL.TSK/TASK=...CA0
>INS LB1:[4,54]POLICE/TASK=...CA1
>INS LB1:[1,1]NDTBAS/RON=YES/PAR=GEN
>INS LB1:[1,1]MIMRES/RON=YES/PAR=GEN
>INS $BAD
>INS $BRU
>INS $CMP
>INS $CRF
>INS $DMP
>INS $LBR
>INS $MAC
>INS $RPT
>INS $SLP
>INS $TKB
>INS $VFY
>INS $VMR
>INS $ZAP
>INS LB1:[4,54]BICRES
>INS LB1:[4,54]DOBRES
>INS LB1:[4,54]DUP/INC=18000.
>INS LB1:[4,54]ERR
>INS LB1:[4,54]MIMRES
>INS LB1:[4,54]MIMRES/TASK=...NDT
>INS LB1:[4,54]MIMRES/TASK=...MMM
>INS LB1:[4,54]MO
>INS LB1:[4,54]SRDRES
>ACD UNLINK TI:
>ACD REMOVE NUMBER 20
That ACD is not installed
>ACD INSTALL LB1:[ACD2]MIMACD.TSK AS NUMBER 20 ASSIGN ACD$MIM
>ACD LINK TI: TO NUMBER 20
>@ <EOF>
>CD 1,54
>@VMR
>;PIP RSX11M.SYS;*/DE
>PIP RSX11M.SYS/UP=RSX11M.TSK
>ASN SY:=LB:
>VMR @SYSVMR
VMR -- *DIAG*-Installed tasks or commons may no longer fit in partition
SET /TOP=SYSPAR:-*
VMR -- *DIAG*-Loadable driver larger than 4K
LOA TT:/SIZE=16300
SET /TOP=DRVPAR:-*
SECPOL 117734 00120000 00100000 SEC POOL
SYSPAR 117670 00220000 00201000 MAIN
117624 00220000 00111300 RO COM !DIR11M!
117440 00331300 00004400 TASK [...LDR]
117240 00335700 00033500 TASK [MCR...]
117040 00371400 00010500 TASK [TKTN ]
116640 00402100 00003200 TASK [SHF...]
116440 00405300 00013500 TASK [RCT...]
DRVPAR 116360 00421000 00136200 MAIN
116314 00421000 00006300 RO COM !TTEXT !
116230 00427300 00036000 DRIVER (TT: )
115220 00465300 00001300 DRIVER (DK: )
115134 00466600 00005100 RO COM !PUCOM !
114024 00473700 00014000 DRIVER (DU: )
113450 00507700 00011500 DRIVER (MU: )
113240 00521400 00000100 DRIVER (NL: )
113174 00521500 00017700 DRIVER (VF: )
113130 00541400 00002500 DRIVER (VT: )
113064 00544100 00001500 DRIVER (RD: )
112004 00545600 00002300 DRIVER (ZA: )
110704 00550100 00002300 DRIVER (ZB: )
107604 00552400 00002300 DRIVER (ZC: )
106504 00554700 00002300 DRIVER (ZD: )
GEN 106420 00557200 01220600 MAIN
106354 00557200 00002000 RO COM !DYCOM !
...LDR 12.01 117504 SYSPAR 248. 00004400 LB0:-00065004 FIXED
TKTN 07.01 117104 SYSPAR 248. 00010500 LB0:-00115424 FIXED
F11MSG 15.00 104444 GEN 200. 00006300 LB0:-00103656
MTAACP 17.00 104064 GEN 200. 00016200 LB0:-00110340
MCR... 07.00 117304 SYSPAR 160. 00033500 LB0:-00107315 FIXED
F11ACP 07.00 106124 GEN 149. 00011100 LB0:-00102326
ERRLOG 05.03 105574 GEN 148. 00056200 LB0:-00102244
PMT... 02.02 105144 GEN 148. 00007500 LB0:-00111251
HRC... 05.00 104204 GEN 140. 00042500 LB0:-00104442
PMD... 07.05 103744 GEN 140. 00017600 LB0:-00111221
SYSLOG 04.03 104704 GEN 130. 00024500 LB0:-00114275
SHF... 07.01 116704 SYSPAR 105. 00003200 LB0:-00114054 FIXED
RCT... 06.02 116504 SYSPAR 100. 00013500 LB0:-00111714 FIXED
FXR... 03.02 104324 GEN 100. 00003300 LB0:-00103650
BAP0 04.11 105714 GEN 80. 00050300 LB0:-00074142
QMG... 06.04 105024 GEN 75. 00037300 LB0:-00111653
LP0 07.04 105360 GEN 70. 00020300 LB0:-00106633
ACNT 06.04 104564 GEN 50. 00057600 LB0:-00073603
SHUTUP 04.04 103624 GEN 50. 00016500 LB0:-00114061
...RMD 05.00 001236+ GEN 225. 00042000 LB0:-00111737
...DCL 06.01 001212+ GEN 160. 00062500 LB0:-00077004
...DMO 04.02 001214+ GEN 160. 00017300 LB0:-00077760
...MCR 07.00 001230+ GEN 160. 00040300 LB0:-00107353
...MOU 26.06 001232+ GEN 160. 00045600 LB0:-00110246
...CA. 01.00 001264+ GEN 150. 00026100 LB0:-00114331
...INS 16.00 001226+ GEN 100. 00053200 LB0:-00105327
...SAV 11.00 001262+ GEN 100. 00071300 LB0:-00065224
...UFD 07.02 001266+ GEN 100. 00014500 LB0:-00115437
...VCP V04.10 001270+ GEN 90. 00020300 LB0:-00115625
...ACS 04.00 001244+ GEN 70. 00006200 LB0:-00073761
...ACC 05.00 001204+ GEN 65. 00032100 LB0:-00073267
...AT. 10.0 001220+ GEN 64. 00056700 LB0:-00105062
...INI 24.00 001222+ GEN 60. 00037200 LB0:-00105233
...HOM 24.00 001224+ GEN 60. 00037200 LB0:-00105233
...BRO 09.10 001206+ GEN 50. 00041500 LB0:-00074270
...BYE 05.01 001210+ GEN 50. 00021700 LB0:-00074574
...HEL 06.00 001216+ GEN 50. 00031600 LB0:-00104006
...PIP 21.00 001234+ GEN 50. 00036400 LB0:-00111041
...UNL 05.04 001240+ GEN 50. 00021500 LB0:-00115553
...ACD 03.00 001242+ GEN 50. 00042500 LB0:-00073360
...BOO 03.10 001246+ GEN 50. 00051400 LB0:-00074066
...CON 05.00 001250+ GEN 50. 00135600 LB0:-00076265
...ELI 04.03 001252+ GEN 50. 00032600 LB0:-00102207
...LOA 05.03 001254+ GEN 50. 00040000 LB0:-00106436
...MAG 03.00 001256+ GEN 50. 00037300 LB0:-00107253
...PSW 03.02 001260+ GEN 50. 00017500 LB0:-00111336
YLA OFL CPA CSR=177560 VEC=60 PRI=5
YLB OFL CPA CSR=176520 VEC=320 PRI=5
YLC OFL CPA CSR=176530 VEC=330 PRI=5
YLD OFL CPA CSR=176540 VEC=340 PRI=5
YVA OFL CPA CSR=160040 VEC=400 PRI=5
DKA OFL CPA CSR=177404 VEC=220 PRI=5
DUA OFL CPA CSR=172150 VEC=154 PRI=5
MUA OFL CPA CSR=174500 VEC=260 PRI=5
ZAA OFL CPA CSR=161014 VEC=350 PRI=4
ZBA OFL CPA CSR=161054 VEC=354 PRI=4
ZCA OFL CPA CSR=161114 VEC=360 PRI=4
ZDA OFL CPA CSR=161154 VEC=364 PRI=4
VF0: OFL DRIVER
VF1: OFL DRIVER
VF2: OFL DRIVER
VF3: OFL DRIVER
VF4: OFL DRIVER
VF5: OFL DRIVER
VF6: OFL DRIVER
VF7: OFL DRIVER
VF10: OFL DRIVER
VF11: OFL DRIVER
VF12: OFL DRIVER
VF13: OFL DRIVER
VF14: OFL DRIVER
VF15: OFL DRIVER
VF16: OFL DRIVER
VF17: OFL DRIVER
TT0: YLA0: OFL DRIVER
TT1: YLB0: OFL DRIVER
TT2: YLC0: OFL DRIVER
TT3: YLD0: OFL DRIVER
TT4: YVA0: OFL DRIVER
TT5: YVA1: OFL DRIVER
TT6: YVA2: OFL DRIVER
TT7: YVA3: OFL DRIVER
TT10: YVA4: OFL DRIVER
TT11: YVA5: OFL DRIVER
TT12: YVA6: OFL DRIVER
TT13: YVA7: OFL DRIVER
VT0: OFL DRIVER
RD0: ONL DRIVER
DK0: DKA0: OFL DRIVER
DK1: DKA1: OFL DRIVER
DK2: DKA2: OFL DRIVER
DK3: DKA3: OFL DRIVER
DK4: DKA4: OFL DRIVER
DK5: DKA5: OFL DRIVER
DK6: DKA6: OFL DRIVER
DK7: DKA7: OFL DRIVER
DU0: DUA0: OFL DRIVER
DU1: DUA1: OFL DRIVER
DU2: DUA2: OFL DRIVER
DU3: DUA3: OFL DRIVER
DU4: DUA4: OFL DRIVER
DU5: DUA5: OFL DRIVER
DU6: DUA6: OFL DRIVER
DU7: DUA7: OFL DRIVER
MU0: MUA0: OFL DRIVER
NL0: OFL DRIVER
ZA0: ZAA0: OFL DRIVER
ZA1: ZAA1: OFL DRIVER
ZA2: ZAA2: OFL DRIVER
ZA3: ZAA3: OFL DRIVER
ZA4: ZAA4: OFL DRIVER
ZA5: ZAA5: OFL DRIVER
ZA6: ZAA6: OFL DRIVER
ZA7: ZAA7: OFL DRIVER
ZA10: ZAA10: OFL DRIVER
ZA11: ZAA11: OFL DRIVER
ZB0: ZBA0: OFL DRIVER
ZB1: ZBA1: OFL DRIVER
ZB2: ZBA2: OFL DRIVER
ZB3: ZBA3: OFL DRIVER
ZB4: ZBA4: OFL DRIVER
ZB5: ZBA5: OFL DRIVER
ZB6: ZBA6: OFL DRIVER
ZB7: ZBA7: OFL DRIVER
ZB10: ZBA10: OFL DRIVER
ZB11: ZBA11: OFL DRIVER
ZC0: ZCA0: OFL DRIVER
ZC1: ZCA1: OFL DRIVER
ZC2: ZCA2: OFL DRIVER
ZC3: ZCA3: OFL DRIVER
ZC4: ZCA4: OFL DRIVER
ZC5: ZCA5: OFL DRIVER
ZC6: ZCA6: OFL DRIVER
ZC7: ZCA7: OFL DRIVER
ZC10: ZCA10: OFL DRIVER
ZC11: ZCA11: OFL DRIVER
ZD0: ZDA0: OFL DRIVER
ZD1: ZDA1: OFL DRIVER
ZD2: ZDA2: OFL DRIVER
ZD3: ZDA3: OFL DRIVER
ZD4: ZDA4: OFL DRIVER
ZD5: ZDA5: OFL DRIVER
ZD6: ZDA6: OFL DRIVER
ZD7: ZDA7: OFL DRIVER
ZD10: ZDA10: OFL DRIVER
ZD11: ZDA11: OFL DRIVER
POOL=1200:3432.:03432.:1200
>ASN =LB:
>@ <EOF>
  OO [1,54]RSX11M
SAV /WB
>RED ZC1:=SY:
>RED ZC1:=LB:
>RED ZC1:=SP:
>@ZC1:[1,2]STARTUP
>; PLEASE NOTE
>* Please enter time and date (HH:MM DD-MMM-YYYY) [S]: 20:45 17-APR-2021
>TIME 20:45 17-APR-2021
>ACS SY:/BLKS=1024.
>CON ONLINE ALL
>ELI /LOG/LIM
>INS $QMGCLI
>QUE /START:QMG
>QUE LP0:/CR/NM
>START/ACCOUNTING
>CON ESTAT LP0:
>QUE BAP0:/BATCH
>QUE BAP0:/AS:BATCH
>SET /EBC=TI:
>MOU VF0:UTILS/PUB
>ASN VF0:=LB1:/GBL
>REM ...CA.
>INS $BAD
>INS $BRU
>INS $CMP
>INS $CRF
>INS $DMP
>INS $LBR
>INS $MAC
>INS $RPT
>INS $SLP
>INS $TKB
>INS $VFY
>INS $VMR
>INS $ZAP
>INS LB1:[4,54]ERR
>INS LB1:[4,54]MO
>ACD UNLINK TI:
>@ <EOF>
>DEV
VF0: Public Mounted Loaded Label=UTILS Type=unknown
TT1: Offline Loaded
TT2: Offline Loaded
TT3: Loaded
TT4: Offline Loaded
TT5: Offline Loaded
TT6: Offline Loaded
TT7: Offline Loaded
VT0: Loaded
VT1: Loaded
RD0: Loaded
DK0: Loaded Type=RK05
DK1: Loaded Type=RK05
DK2: Loaded Type=RK05
DK3: Loaded Type=RK05
DK4: Loaded Type=RK05
DK5: Loaded Type=RK05
DK6: Loaded Type=RK05
DK7: Loaded Type=RK05
MU0: Offline Loaded Type=unknown
NL0: Loaded
ZC1: Public Mounted Loaded Label=RSX11MPBL87 Type=UNKN
ZD1: Loaded Type=UNKN
TI0:
CO0: TT0:
CL0: TT0:
SP0: ZC1:
LB0: ZC1:
SY0: ZC1:
Weird. The picture of the KDJ11-B do not have an FPA installed. You can see the socket, but it's empty.
Did you pick a picture from somewhere else, or did you remove that chip before the photo?
Apart from that, nice. How stable is it?
The photo was taken before the purchased FPA arrived, but after I replaced the 15,206 МНz (yes, it was M8190-AB board) quartz with a 20 MHz quartz.
The log was recorded in the current configuration and it can be seen from it that the clock frequency is almost 24 MHz and the FPA is present
But I can take new photos - in current configuration
Very stable - to evaluate the performance, I made a complete RSX-11M-Plus Sysgen several times.
All my J-11 -09 processors run at 20 MHz, but not all run at 24 MHz.
How stable is it?
That'll be the interesting question. The 2 gate arrays were twitchy even with a 20 MHz crystal (5MHz clock) - I had to try quite a few boards before I found one that would run reliably. But that was with earlier boards and J-11 chips - all DCJ11-AE are at least rev 1 on the DC334 and rev 11 on the DC335, but the masks continued to evolve without changing the DCJ11 suffix - the last ones I've seen were rev 4 on the DC334 and rev 16 on the DC335, with a 9820 module date code and a Harris Semiconductor logo on the ceramic carrier instead of the usual DIGITAL. Based on the date, that was likely one of the last J-11 chips produced.
Presumably similar things went on with the support gate arrays. One of the first things to fail reliably at higher clock speeds during my tests was PMI memory.
I have theorized in the past that needing to at least re-spin (and possibly redesign) those gate arrays was one of the reasons DEC was less vocal about Harris not meeting the original speed goal. Of course, just because DEC used gate arrays that couldn't keep up doesn't mean that other CPU boards had the same limitations - the Nissho 11/24 upgrade didn't use them, and neither the the 11/93-94 CPU board from ROI.
Hmm. Maybe something I should experiment with one of these days on one of my KDJ11-E boards.
All of my J11-04 have DC334-01 and DC335-10
J11-04A1 - DC334-01 and DC335-10
J11-07 - DC334-04 and DC335-15
Both J11-08 - DC334-01 and DC335-11
And all of my J11-09 have DC334-04 and DC335-16
I have a pair of KDJ11-A (М8192 and M8192-YB) and I decided to see if it would be possible to change quartz for M8192-YB, from the standard 15.206 MHz to 24 MHz. With changing the processor of course.
To my slight surprise, the board are starting, but speed tests were surprising.
All are same, only the quartz and the processor were changed. All results are operations per second. Mark "emp" (empty) - block for calculating the impact of overhead costs.
                              15.206, no cache  24, no cache      15.206, cache         24, cache
R0(23456.)+R0(12345.) emp.    154 284           172 457           926 354             1 457 892
R1(23456.)+R0(12345.)         123 428> 617 156  137 556> 679 708  744 540> 3 793 479  1 172 443> 5 988 093
R1(23456.)+@R0(M-12345.) emp. 154 284           172 457           926 353             1 457 884
R1(23456.)+@R0(M-12345.)       98 286> 270 794  110 776> 309 724  534 663> 1 264 486    842 556> 1 996 250
11.*12. emp.                  154 284           172 457           926 353             1 457 887
11.*12.                        73 243> 139 438   92 650> 200 209  145 371>   172 430    229 379>   272 207
R2-R3(34567.)/R1(321.) emp.   123 428           137 556           744 541             1 172 444
R2-R3(34567.)/R1(321.)         54 234>  96 742   70 155> 143 176   97 005>   111 536    153 090>   176 081
34567./321. (FPU) emp.         25 837            35 865            36 433                57 506
34567./321. (FPU)              12 022>  22 483   17 709>  34 982   14 182>    23 221     22 413>    36 727
34567.89022+32109.754321 emp.  36 089            44 243            90 117                142 220
34567.89022+32109.754321       23 471>  67 129   30 817> 101 551   40 748>    74 380      64 315>  117 410
34567.89022*32109.754321 emp.  36 089            44 243            90 117                142 220
34567.89022*32109.754321       13 600>  21 824   19 225>  33 998   18 027>    22 534     28 478>    35 608
34567.89022/32109.754321 emp.  36 089            44 243            90 117               142 220
34567.89022/32109.754321       13 705>  22 096   19 757>  35 698   18 227>    22 848    28 764>     36 056
MOV 8 word 1 emp.             102 985           114 774           622 987               981 476
MOV 8 word 1                   11 625>  13 104   13 560>  15 376   28 975>    30 388     39 649>    41 318
MOV 8 word 2 emp.             102 857           114 972           622 208               980 249
MOV 8 word 2                   14 169>  16 432   16 489>  19 249   34 197>    36 185     45 694>    47 928
R1 := M(word)                 189 641           215 838           927 510             1 459 711
R1 := M(even byte)            189 405           215 568           926 352             1 457 896
R1 := M(odd byte)             189 405           215 567           926 352             1 459 896
CLR R0 - SOB R0, . emp.       617 145           687 787           187 277               490 858
CLR R0 - SOB R0,                   3>        3        4>       4       11>        11         18>        18
As I have posted here before, I once upgraded an 11/83 to 22.1184 MHz, and it passed all diagnostics, etc. That particular board would talk to the console but would not boot successfully at 24 MHz.
I ran my own KDJ11-B 11/73 at 18 MHz for years with no troubles. I don't remember trying to go faster on that board, but maybe I did...
@173000g
9 Step memory test
Trying ZB1
RT-11SB (S) V05.07
.R MSCPCK
.ini dl2:
DL2:/Initialize; Are you sure? Y
.cop/ver/sys/excl sy:*.dsk dl2:
Files copied:
SY:SWAP.SYS to DL2:SWAP.SYS
SY:RT11SB.SYS to DL2:RT11SB.SYS
SY:RT11FB.SYS to DL2:RT11FB.SYS
SY:RK.SYS to DL2:RK.SYS
SY:DL.SYS to DL2:DL.SYS
SY:DU.SYS to DL2:DU.SYS
SY:HX.SYS to DL2:HX.SYS
SY:ZA.SYS to DL2:ZA.SYS
SY:ZB.SYS to DL2:ZB.SYS
SY:ZC.SYS to DL2:ZC.SYS
SY:ZD.SYS to DL2:ZD.SYS
SY:ZE.SYS to DL2:ZE.SYS
SY:ZF.SYS to DL2:ZF.SYS
SY:WQ.SYS to DL2:WQ.SYS
SY:WS.SYS to DL2:WS.SYS
SY:LD.SYS to DL2:LD.SYS
SY:VM.SYS to DL2:VM.SYS
SY:MU.SYS to DL2:MU.SYS
SY:NL.SYS to DL2:NL.SYS
SY:SL.SYS to DL2:SL.SYS
SY:RT11XM.SYS to DL2:RT11XM.SYS
SY:RT11XB.SYS to DL2:RT11XB.SYS
SY:RT11ZM.SYS to DL2:RT11ZM.SYS
SY:RT11ZB.SYS to DL2:RT11ZB.SYS
SY:RKX.SYS to DL2:RKX.SYS
SY:DLX.SYS to DL2:DLX.SYS
SY:DUX.SYS to DL2:DUX.SYS
SY:HXX.SYS to DL2:HXX.SYS
SY:ZAX.SYS to DL2:ZAX.SYS
SY:ZBX.SYS to DL2:ZBX.SYS
SY:ZCX.SYS to DL2:ZCX.SYS
SY:ZDX.SYS to DL2:ZDX.SYS
SY:ZEX.SYS to DL2:ZEX.SYS
SY:ZFX.SYS to DL2:ZFX.SYS
SY:WQX.SYS to DL2:WQX.SYS
SY:WSX.SYS to DL2:WSX.SYS
SY:LDX.SYS to DL2:LDX.SYS
SY:VMX.SYS to DL2:VMX.SYS
SY:MUX.SYS to DL2:MUX.SYS
SY:NLX.SYS to DL2:NLX.SYS
SY:SLX.SYS to DL2:SLX.SYS
SY:NQX.SYS to DL2:NQX.SYS
SY:PIP.SAV to DL2:PIP.SAV
SY:DUP.SAV to DL2:DUP.SAV
SY:DIR.SAV to DL2:DIR.SAV
SY:IND.SAV to DL2:IND.SAV
SY:RESORC.SAV to DL2:RESORC.SAV
SY:EDIT.SAV to DL2:EDIT.SAV
SY:KED.SAV to DL2:KED.SAV
SY:KEX.SAV to DL2:KEX.SAV
SY:MACRO.SAV to DL2:MACRO.SAV
SY:CREF.SAV to DL2:CREF.SAV
SY:LINK.SAV to DL2:LINK.SAV
SY:MONMRG.SAV to DL2:MONMRG.SAV
SY:LIBR.SAV to DL2:LIBR.SAV
SY:FILEX.SAV to DL2:FILEX.SAV
SY:SRCCOM.SAV to DL2:SRCCOM.SAV
SY:BINCOM.SAV to DL2:BINCOM.SAV
SY:SLP.SAV to DL2:SLP.SAV
SY:DUMP.SAV to DL2:DUMP.SAV
SY:SIPP.SAV to DL2:SIPP.SAV
SY:BUP.SAV to DL2:BUP.SAV
SY:PAT.SAV to DL2:PAT.SAV
SY:HELP.SAV to DL2:HELP.SAV
SY:SYSMAC.SML to DL2:SYSMAC.SML
SY:SYSLIB.OBJ to DL2:SYSLIB.OBJ
SY:FORMAT.SAV to DL2:FORMAT.SAV
SY:SETUP.SAV to DL2:SETUP.SAV
SY:VTCOM.SAV to DL2:VTCOM.SAV
SY:DATIME.SAV to DL2:DATIME.SAV
SY:DATIME.MAC to DL2:DATIME.MAC
SY:DATIME.COM to DL2:DATIME.COM
SY:LET.SAV to DL2:LET.SAV
SY:SPLIT.SAV to DL2:SPLIT.SAV
SY:UCL.SAV to DL2:UCL.SAV
SY:VBGEXE.SAV to DL2:VBGEXE.SAV
SY:TERMID.SAV to DL2:TERMID.SAV
SY:TRANSF.SAV to DL2:TRANSF.SAV
SY:TRANSF.TSK to DL2:TRANSF.TSK
SY:TRANSF.EXE to DL2:TRANSF.EXE
SY:ODT.OBJ to DL2:ODT.OBJ
SY:VDT.OBJ to DL2:VDT.OBJ
SY:MDUP.SAV to DL2:MDUP.SAV
SY:MBOOT.BOT to DL2:MBOOT.BOT
SY:MBOT16.BOT to DL2:MBOT16.BOT
SY:MSBOOT.BOT to DL2:MSBOOT.BOT
SY:MDUP.AI to DL2:MDUP.AI
SY:MDUP.MM to DL2:MDUP.MM
SY:MDUP.MS to DL2:MDUP.MS
SY:MDUP.MT to DL2:MDUP.MT
SY:MDUP.MU to DL2:MDUP.MU
SY:VERIFY.COM to DL2:VERIFY.COM
SY:IVP.COM to DL2:IVP.COM
SY:IVP.MAC to DL2:IVP.MAC
SY:MTB.COM to DL2:MTB.COM
SY:MSB.COM to DL2:MSB.COM
SY:MUB.COM to DL2:MUB.COM
SY:SB.MAC to DL2:SB.MAC
SY:FB.MAC to DL2:FB.MAC
SY:XM.MAC to DL2:XM.MAC
SY:XB.MAC to DL2:XB.MAC
SY:ZM.MAC to DL2:ZM.MAC
SY:ZB.MAC to DL2:ZB.MAC
SY:SYSTEM.MLB to DL2:SYSTEM.MLB
SY:EDTL.MLB to DL2:EDTL.MLB
SY:SYSGEN.COM to DL2:SYSGEN.COM
SY:CONFIG.COM to DL2:CONFIG.COM
SY:CONFIG.SAV to DL2:CONFIG.SAV
SY:V5USER.TXT to DL2:V5USER.TXT
SY:V5NOTE.TXT to DL2:V5NOTE.TXT
SY:CUSTOM.TXT to DL2:CUSTOM.TXT
SY:MSCPCK.SAV to DL2:MSCPCK.SAV
SY:DBGSYM.SAV to DL2:DBGSYM.SAV
SY:INDEX.SAV to DL2:INDEX.SAV
SY:INDEXX.SAV to DL2:INDEXX.SAV
SY:INDEXA.IMG to DL2:INDEXA.IMG
SY:INDEXB.IMG to DL2:INDEXB.IMG
SY:INDEX.IDX to DL2:INDEX.IDX
SY:TECO.SAV to DL2:TECO.SAV
SY:SGN02.CND to DL2:SGN02.CND
SY:SGN02.ANS to DL2:SGN02.ANS
SY:SGN02.BLD to DL2:SGN02.BLD
SY:SGN02.MON to DL2:SGN02.MON
SY:SGN02.DEV to DL2:SGN02.DEV
SY:SGN02.TBL to DL2:SGN02.TBL
SY:RT11SB.MAP to DL2:RT11SB.MAP
SY:RT11FB.MAP to DL2:RT11FB.MAP
SY:RT11XM.MAP to DL2:RT11XM.MAP
SY:RT11XB.MAP to DL2:RT11XB.MAP
SY:RT11ZM.MAP to DL2:RT11ZM.MAP
SY:RT11ZB.MAP to DL2:RT11ZB.MAP
SY:STRTSB.COM to DL2:STRTSB.COM
SY:STRTFB.COM to DL2:STRTFB.COM
SY:STRTXM.COM to DL2:STRTXM.COM
SY:STRTXB.COM to DL2:STRTXB.COM
SY:STRTZM.COM to DL2:STRTZM.COM
SY:STRTZB.COM to DL2:STRTZB.COM
SY:HELAY.SYS to DL2:HELAY.SYS
SY:EM.SYS to DL2:EM.SYS
SY:TSYB10.COM to DL2:TSYB10.COM
SY:TSYNL.COM to DL2:TSYNL.COM
SY:SYSGEN.TMP to DL2:SYSGEN.TMP
SY:HAND.SAV to DL2:HAND.SAV
SY:DESS.SAV to DL2:DESS.SAV
SY:SPEED3.SAV to DL2:SPEED3.SAV
SY:SPEED4.SAV to DL2:SPEED4.SAV
SY:GETMEM.SAV to DL2:GETMEM.SAV
SY:GETMEM.MAC to DL2:GETMEM.MAC
SY:GETMEM.OBJ to DL2:GETMEM.OBJ
SY:ROM.BIN to DL2:ROM.BIN
SY:TSYA10.COM to DL2:TSYA10.COM
SY:TDL0NL.COM to DL2:TDL0NL.COM
SY:TDL0.COM to DL2:TDL0.COM
SY:TSYDL0.COM to DL2:TSYDL0.COM
.cop/boo dl2:rt11zm dl2:
147250
@173000g
9 Step memory test
Type a command then press the RETURN key: BOO DL2
Trying DL2
Starting system from DL2
RT-11ZM (S) V05.07
.TYPE V5USER.TXT
RT-11 V5.7
Installation of RT-11 Version 5.7 is complete and you are now running
RT-11 from your system volume.
Your system volume is your working volume if you have used the Automatic
Installation (AI) procedure. If you have installed RT-11 using that
procedure, Mentec recommends you verify the correct operation of your
system's software using the VERIFY verification procedure. You can only
perform VERIFY on the valid target (output) media you used for the AI
procedure. Run VERIFY before you run CONFIG. To run VERIFY, enter the
command:
IND VERIFY
You should read the file V5NOTE.TXT, which you can TYPE or PRINT. Also,
read the Introduction to RT-11, and the Installation Guide which
contain much of the information you need to use RT-11 Version 5.7.
.R MSCPCK
.sho all
RT-11ZM (S) V05.07
Booted from DL2:RT11ZM
22 bit addressing is on
USR is set NOSWAP
EXIT is set SWAP
KMON is set NOIND
RUN is set NOVBGEXE
MODE is set NOSJ
TT is set NOQUIET
ERROR is set ERROR
SL is set OFF
EDIT is set KEX
PDP 11/83 Processor
4088KB of memory
Parity Memory
Cache Memory
PMI Memory
FPU support
Device Status CSR Vector(s)
RK Not installed 177400 220
DL Resident 174400 160
DU Installed 172150 154
HX Installed 177560 000
ZA Installed 161014 350
ZB Installed 161054 354
ZC Installed 161114 360
ZD Installed 161154 364
ZE Not installed 161214 370
ZF Not installed 161254 374
WQ Not installed 177134 204
WS Not installed 177134 204
LD Installed 000000 000
VM Installed 177572 000
MU Not installed 174500 260
NL Installed 000000 000
SL Installed 000000 000
NQ Not installed 174440 120
TT (Resident)
DL (Resident)
DL2 = DK , SY
MQ (Resident)
HX
ZA
ZB
ZC
DU
VM
ZD
LD
NL
SL
15 free slots
Job Name Console Level State Low High Impure
0 RESORC 0 0 Run 000000 100564 115176
No multi-terminal support
------- Extended Memory --------
Address Module Words Type
17760000 IOPAGE 4096. PRM HDW BYP
17760000 MEMTOP
00760000 VM 1966080. SHR
00220300 ...... 90016.
00205700 SL 2688. PVT
00163000 DU 4832. PVT
00160000 MCA 768. PRM
00000000 KERNEL 28672. PRM HDW
------ Low Memory -------
155332 DL 659.
112630 RMON 8865.
100566 USR 2577.
001000 ..BG.. 16315.
LD0 is ZB3:S00.DSK[1950.] #
# Handler not loaded
137134
@17300-?
@0g
116312
@173000g
9 Step memory test
Type a command then press the RETURN key: BOO DL0
Trying DL0
Starting system from DL0
RSX-11M-PLUS V4.6 BL87 2044.KW System:"DE10 "
>RED DL:=SY:
>RED DL:=LB:
>RED DL:=SP:
>MOU DL0:"RSX11MPBL87"
>@DL:[1,2]STARTUP
>; PLEASE NOTE
>* Please enter time and date (HH:MM DD-MMM-YYYY) [S]: 19:11 15-may-2021
>TIME 19:11 15-may-2021
>ACS SY:/BLKS=1024.
>CON ONLINE ALL
>ELI /LOG/LIM
>INS $QMGCLI
>QUE /START:QMG
>QUE LP0:/CR/NM
>START/ACCOUNTING
>CON ESTAT LP0:
>QUE BAP0:/BATCH
>QUE BAP0:/AS:BATCH
>@ <EOF>
>dev dl:
DL0: Public Mounted Loaded Label=RSX11MPBL87 Type=RL02
Seek_Optimization=Nearest:10.
DL1: Loaded Type=RL02
DL2: Loaded Type=RL02
DL3: Loaded Type=RL02
>mou dl1:/for/nowr
>mou dl3:/for
>bru/ini/ver dl1: dl3:
MCR -- Task not in system
>ins $bru
>bru/ver/ini dl1: dl3:
BRU - Starting verify pass
19:15:54 Login failure INVALID USER TT4:
19:16:06 Login user SYSTEM [1,1] TT4:
BRU - Completed
19:19:30 Login user SYSTEM [1,1] TT1:
19:19:34 Logout user SYSTEM [1,1] TT1:
19:19:38 Logout user SYSTEM [1,1] TT4:
run shutup
RSX-11M-PLUS Shut down program
Enter minutes to wait before shutdown:
Reason for shutdown (<CR> for none):
OK to shutdown? [Y/N]: y
All further logins are disabled
15-MAY-2021 19:19 System is now shutting down -- DE10
QUE /STO:QMG
STOP/ACCOUNTING SHUTUP
19:19:59 SYSLOG -- 47. Exiting
@LB:[1,2]SHUTUP
>VCP DISCONNECT /ALL
>@ <EOF>
ELI /NOLOG
ACS DL0:/BLKS=0.
ACS -- Checkpoint file now inactive
DMO DL0:/DEV/LOCK=V
DMO -- System disk being dismounted
DMO -- SYSTEM dismounted from DL0: *** Final dismount initiated ***
19:20:01 *** DL0: -- Dismount complete
DMO DL1:/DEV/LOCK=V
19:20:06 *** DL1: -- Dismount complete
DMO -- TT0: dismounted from DL1: *** Final dismount initiated ***
DMO DL3:/DEV/LOCK=V
19:20:11 *** DL3: -- Dismount complete
DMO -- TT0: dismounted from DL3: *** Final dismount initiated ***
SHUTUP operation complete
126130
@173000G
9 Step memory test
Type a command then press the RETURN key: BOO DL3
Trying DL3
Starting system from DL3
>RED DL3:=SY:
>RED DL3:=LB:
>RED DL3:=SP:
>MOU DL3:"RSX11MPBL87"
>@DL3:[1,2]STARTUP
>; PLEASE NOTE
>@ <EOF>
>RUN SHUTUP
OK to shutdown? [Y/N]: Y
30-MAR-1982 00:00 System is now shutting down -- DE10
@LB:[1,2]SHUTUP
>VCP DISCONNECT /ALL
>@ <EOF>
DMO DL3:/DEV/LOCK=V
DMO -- SYSTEM dismounted from DL3: *** Final dismount initiated ***
00:00:28 *** DL3: -- Dismount complete
126130
PDP-11/83 (not 84!) with RK11 (emulated with FPGA and SD card)
@173000G
9 Step memory test
Type a command then press the RETURN key: BOO DK7
Trying DK7
Starting system from DK7
RT-11SB (S) V05.07
.R MSCPCK
.SHO ALL
RT-11SB (S) V05.07
Booted from RK7:RT11SB
USR     is set SWAP
EXIT    is set SWAP
KMON    is set NOIND
MODE    is set NOSJ
TT      is set NOQUIET
ERROR   is set ERROR
SL      is set OFF
EDIT    is set KED
PDP 11/83 Processor
4088KB of memory
Parity Memory
Cache Memory
PMI Memory
SB timer support
FPU support
RK     Resident           177400    220
DL     Not installed      174400    160
VM     Installed          177572    250
EM     Installed          000000    010
TT (Resident)
   RK (Resident)
RK7 = DK , SY
HX
ZA
ZB
DU
VM
ZC
ZD
NL
LD
SL
EM
13 free slots
 0    RESORC   0      0   Run      000000 135334  137226
160000  IOPAGE  4096.
157330  RK       148.
135400  RMON    4588.
001000  ..BG.. 23680.
No LD units mounted
.COP/DEV/VER RK7: RK6:
RK6:/Copy; Are you sure? Y
.COP/BOO RK6:RT11XM RK6:
.BOO RK6:
RT-11XM (S) V05.07
.TYPE V5USER.TXT
RT-11 V5.7
command:
IND VERIFY
.R MSCPCK
.SHO ALL
RT-11XM (S) V05.07
Booted from RK6:RT11XM
USR     is set NOSWAP
EXIT    is set SWAP
KMON    is set NOIND
RUN     is set NOVBGEXE
MODE    is set NOSJ
TT      is set NOQUIET
ERROR   is set ERROR
SL      is set OFF
EDIT    is set KEX
PDP 11/83 Processor
4088KB of memory
Parity Memory
Cache Memory
PMI Memory
FPU support
SL      Not installed   000000  000
TT (Resident)
   RK (Resident)
RK6 = DK , SY
MQ (Resident)
HX
ZA
ZB
ZC
DU
VM
ZD
LD
NL
16 free slots
 0    RESORC   0      0   Run    000000 105204 121616
17760000  MEMTOP
00204100  ......   93152.
00161200  DU        4832.  PVT
00160000  MCA        320.  PRM
157276  RK       161.
117250  RMON    8203.
105206  USR     2577.
001000  ..BG.. 17475.
.INI RK7:
RK7:/Initialize; Are you sure? Y
Volume contains protected files; Are you sure? Y
.@TSYNL
.TIME
00:02:22
.COPY/DEVICE/NOQUERY SY: NL:
.TIME
00:02:28
The obvious question is how you deal with the fact that any RK11 controller only knows about 18-bit DMA addressing, while a Qbus have 22 bits. Did you do any changes to the driver to use a bounce buffer, or did you change/extend the controller to do 22-bit DMA addressing, and corresponding changes to the RK driver, or is it just running, and things work as long as you don't actually do DMA to addresses above 18 bits?
I chose the easiest way - made Unibus Mappging registers. A little later there will be a log from the RSX.
Interesting. So I assume they work the same as on a Unibus machine. Then you just need to make sure the DK driver is aware that it should use these, and you should be good. And I expect that shouldn't be too hard, since the DK will always use the Unibus map if a larger address space exists, since the controller only normally exists for Unibus.
But you also don't want the Unibus map used for proper Qbus devices, which can directly do the 22-bit addressing.
For some controllers, like MSCP and RL, this might get a bit exciting, as the same drivers normally are used on both type of systems.
But thanks for the info.
Log from RSX-11M-Plus
9 Step memory test
Type a command then press the RETURN key: BOO ZC32
Trying ZC32
Starting system from ZC32
>RED ZC1:=SY:
>RED ZC1:=LB:
>RED ZC1:=SP:
>@ZC1:[1,2]STARTUP
>;                      PLEASE NOTE
>* Please enter time and date (HH:MM DD-MMM-YYYY) [S]: 19:01 10-JUN-2021
>TIME 19:01 10-JUN-2021
>ACS SY:/BLKS=1024.
>CON ONLINE ALL
>ELI /LOG/LIM
>INS $QMGCLI
>QUE /START:QMG
>QUE LP0:/CR/NM
>START/ACCOUNTING
>CON ESTAT LP0:
>QUE BAP0:/BATCH
>QUE BAP0:/AS:BATCH
>SET /EBC=TI:
>MOU VF0:UTILS/PUB
>ASN VF0:=LB1:/GBL
>REM ...CA.
>INS $BAD
>INS $BRU
>INS $CMP
>INS $CRF
>INS $DMP
>INS $LBR
>INS $MAC
>INS $RPT
>INS $SLP
>INS $TKB
>INS $VFY
>INS $VMR
>INS $ZAP
>INS LB1:[4,54]ERR
>INS LB1:[4,54]MO
>ACD UNLINK TI:
>@ <EOF>
>DEV
TT1:     Offline Loaded
TT2:     Loaded
TT3:     Offline Loaded
TT4:     Offline Loaded
TT5:     Offline Loaded
TT6:     Offline Loaded
TT7:     Offline Loaded
VT0:     Loaded
VT1:     Loaded
RD0:     Loaded
NL0:     Loaded
ZA1:     Offline Loaded Type=unknown
ZA2:     Offline Loaded Type=unknown
ZA3:     Offline Loaded Type=unknown
TI0:
CO0:     TT0:
CL0:     TT0:
SP0:     ZC1:
LB0:     ZC1:
SY0:     ZC1:
>MOU DK7:/FOR
>INS $FLX
>FLX DK7:/RT/DI
Directory DK7:
10-JUN-2021
SWAP  .SYS   28. 31-OCT-1998
RT11SB.SYS   99. 02-OCT-2020
RT11FB.SYS  107. 02-OCT-2020
RK    .SYS    3. 02-OCT-2020
DL    .SYS    5. 02-OCT-2020
DU    .SYS   24. 02-OCT-2020
HX    .SYS    6. 12-SEP-2020
ZA    .SYS    4. 05-JUL-2020
ZB    .SYS    4. 05-JUL-2020
ZC    .SYS    4. 05-JUL-2020
ZD    .SYS    4. 05-JUL-2020
ZE    .SYS    4. 05-JUL-2020
ZF    .SYS    4. 05-JUL-2020
WQ    .SYS    4. 05-JUL-2020
WS    .SYS    4. 05-JUL-2020
LD    .SYS   11. 02-OCT-2020
VM    .SYS    3. 02-OCT-2020
MU    .SYS   14. 02-OCT-2020
NL    .SYS    2. 02-OCT-2020
SL    .SYS   17. 31-OCT-1998
RT11XM.SYS  124. 02-OCT-2020
RT11XB.SYS  115. 02-OCT-2020
RT11ZM.SYS  127. 02-OCT-2020
RT11ZB.SYS  118. 02-OCT-2020
RKX   .SYS    3. 02-OCT-2020
DLX   .SYS    5. 02-OCT-2020
DUX   .SYS   27. 02-OCT-2020
HXX   .SYS    6. 12-SEP-2020
ZAX   .SYS    4. 05-JUL-2020
ZBX   .SYS    4. 05-JUL-2020
ZCX   .SYS    4. 05-JUL-2020
ZDX   .SYS    4. 05-JUL-2020
ZEX   .SYS    4. 05-JUL-2020
ZFX   .SYS    4. 05-JUL-2020
WQX   .SYS    4. 05-JUL-2020
WSX   .SYS    4. 05-JUL-2020
LDX   .SYS   11. 02-OCT-2020
VMX   .SYS    3. 02-OCT-2020
MUX   .SYS   19. 02-OCT-2020
NLX   .SYS    2. 02-OCT-2020
SLX   .SYS   20. 31-OCT-1998
NQX   .SYS   10. 02-OCT-2020
PIP   .SAV   30. 31-OCT-1998
DUP   .SAV   52. 31-OCT-1998
DIR   .SAV   20. 31-OCT-1998
IND   .SAV   58. 31-OCT-1998
RESORC.SAV   35. 31-OCT-1998
EDIT  .SAV   19. 31-OCT-1998
KED   .SAV   85. 31-OCT-1998
KEX   .SAV   72. 31-OCT-1998
MACRO .SAV   63. 31-OCT-1998
CREF  .SAV    6. 31-OCT-1998
LINK  .SAV   59. 31-OCT-1998
MONMRG.SAV   14. 31-OCT-1998
LIBR  .SAV   24. 31-OCT-1998
FILEX .SAV   22. 31-OCT-1998
SRCCOM.SAV   26. 31-OCT-1998
BINCOM.SAV   25. 31-OCT-1998
SLP   .SAV   13. 31-OCT-1998
DUMP  .SAV   10. 31-OCT-1998
SIPP  .SAV   21. 31-OCT-1998
BUP   .SAV   68. 31-OCT-1998
PAT   .SAV   11. 31-OCT-1998
HELP  .SAV  161. 31-OCT-1998
SYSMAC.SML   92. 31-OCT-1998
SYSLIB.OBJ   84. 31-OCT-1998
FORMAT.SAV   28. 31-OCT-1998
SETUP .SAV   43. 31-OCT-1998
VTCOM .SAV   24. 31-OCT-1998
DATIME.SAV    4. 31-OCT-1998
DATIME.MAC   23. 31-OCT-1998
DATIME.COM    3. 31-OCT-1998
LET   .SAV    6. 31-OCT-1998
SPLIT .SAV    3. 31-OCT-1998
UCL   .SAV   16. 31-OCT-1998
VBGEXE.SAV   18. 31-OCT-1998
TERMID.SAV    4. 31-OCT-1998
TRANSF.SAV   16. 31-OCT-1998
TRANSF.TSK   76. 31-OCT-1998
TRANSF.EXE   45. 31-OCT-1998
ODT   .OBJ    8. 31-OCT-1998
VDT   .OBJ    8. 31-OCT-1998
MDUP  .SAV   22. 31-OCT-1998
MBOOT .BOT    1. 31-OCT-1998
MBOT16.BOT    1. 31-OCT-1998
MSBOOT.BOT    4. 31-OCT-1998
MDUP  .AI    72. 31-OCT-1998
MDUP  .MM    72. 31-OCT-1998
MDUP  .MS    72. 31-OCT-1998
MDUP  .MT    72. 31-OCT-1998
MDUP  .MU    72. 31-OCT-1998
VERIFY.COM    2. 31-OCT-1998
IVP   .COM   16. 31-OCT-1998
IVP   .MAC   33. 31-OCT-1998
MTB   .COM   16. 31-OCT-1998
MSB   .COM   16. 31-OCT-1998
MUB   .COM   16. 31-OCT-1998
SB    .MAC    1. 31-OCT-1998
FB    .MAC    1. 31-OCT-1998
XM    .MAC    1. 31-OCT-1998
XB    .MAC    1. 31-OCT-1998
ZM    .MAC    1. 31-OCT-1998
ZB    .MAC    1. 31-OCT-1998
SYSTEM.MLB  148. 31-OCT-1998
EDTL  .MLB   11. 31-OCT-1998
SYSGEN.COM  286. 31-OCT-1998
CONFIG.COM   29. 31-OCT-1998
CONFIG.SAV   10. 31-OCT-1998
V5USER.TXT    2. 31-OCT-1998
V5NOTE.TXT   36. 31-OCT-1998
CUSTOM.TXT   14. 31-OCT-1998
MSCPCK.SAV    4. 31-OCT-1998
DBGSYM.SAV   10. 31-OCT-1998
INDEX .SAV   11. 31-OCT-1998
INDEXX.SAV   14. 31-OCT-1998
INDEXA.IMG  164. 31-OCT-1998
INDEXB.IMG  165. 31-OCT-1998
INDEX .IDX    7. 31-OCT-1998
TECO  .SAV   50. 31-OCT-1998
SGN02 .CND    5. 02-OCT-2020
SGN02 .ANS    9. 02-OCT-2020
SGN02 .BLD    3. 02-OCT-2020
SGN02 .MON   10. 02-OCT-2020
SGN02 .DEV    6. 02-OCT-2020
SGN02 .TBL    5. 02-OCT-2020
RT11SB.MAP   34. 02-OCT-2020
RT11FB.MAP   35. 02-OCT-2020
RT11XM.MAP   38. 02-OCT-2020
RT11XB.MAP   36. 02-OCT-2020
RT11ZM.MAP   38. 02-OCT-2020
RT11ZB.MAP   36. 02-OCT-2020
STRTSB.COM    1. 31-OCT-1998
STRTFB.COM    5. 31-OCT-1998
STRTXM.COM    8. 31-OCT-1998
STRTXB.COM    5. 31-OCT-1998
STRTZM.COM    8. 31-OCT-1998
STRTZB.COM    5. 31-OCT-1998
HELAY .SYS    1. 13-JUN-1988
EM   .SYS     4. 04-MAR-2012
TSYB10.COM    1. 16-OCT-2020
TSYNL .COM    1. 16-OCT-2020
SYSGEN.TMP    1.
HAND .SAV     8. 08-NOV-2011
DESS .SAV    18. 22-FEB-2015
SPEED3.SAV    8. 08-FEB-2021
SPEED4.SAV    8. 08-FEB-2021
GETMEM.SAV    3.
GETMEM.MAC    2. 15-APR-2021
GETMEM.OBJ    2.
ROM   .BIN    1.
TSYA10.COM    1.
TDL0NL.COM    1. 07-MAY-2021
TDL0  .COM    1. 11-MAY-2021
TSYDL0.COM    1. 15-MAY-2021
SPEED5.SAV    8. 19-MAY-2021
< Unused > 583.
583. Free blocks
Total of 4179. blocks in 155. files
>DMO DK7:
19:03:48 *** DK7: -- Dismount complete
DMO -- TT0: dismounted from DK7: *** Final dismount initiated ***
>MOU DK7:/FOR
>BAD DK7:/LI
PAR
       117440 00331300 00004400 TASK   <...LDR>
       117240 00335700 00033500 TASK   <MCR...>
       116230 00427300 00036000 DRIVER (TT:)
       115220 00465300 00001300 DRIVER (DK:)
       114024 00473700 00014000 DRIVER (DU:)
       113450 00507700 00011500 DRIVER (MU:)
       113240 00521400 00000100 DRIVER (NL:)
       113174 00521500 00017700 DRIVER (VF:)
       113130 00541400 00002500 DRIVER (VT:)
       113064 00544100 00001500 DRIVER (RD:)
       112004 00545600 00002300 DRIVER (ZA:)
       110704 00550100 00002300 DRIVER (ZB:)
       107604 00552400 00002300 DRIVER (ZC:)
       106504 00554700 00002300 DRIVER (ZD:)
GEN    106420 00557200 17200600 MAIN
       060754 00561200 00007500 TASK   <PMT...>
       062324 00610700 00042500 TASK   <HRC...>
       065510 00653400 00001600 RW COM !ACD20 !
       106060 00662200 00040000 RO COM !FCSRES!
       061154 00730000 00011100 TASK   <F11ACP>
       106270 00741100 00034000 RO COM +F11ACP+
       065620 00775100 00040300 TASK   <PART0 >
       105530 01054000 00057000 RO COM +...AT.+
       105314 01133000 00023000 RO COM +...PIP+
       062700 01203500 00037300 TASK   <QMG...>
       063520 01243000 00024500 TASK   <SYSLOG>
       064024 01267500 00050300 TASK   <BAP0 >
       064270 01413200 00200100 TASK   <BRA >
       064334 01613300 00200100 TASK   <BRB >
       065554 02013400 00200100 TASK   <BRC >
       061220 02213500 00071600 TASK   <BADT0 >
BAD -- DK7: Total bad blocks= 0.
>BRU/INI/VER/MOU/MAX:300./HEAD:295. ZC1:[1,2] DK7:
BRU - This disk will not contain a hardware bootable system
BRU -- *WARNING* -- File IDs will not be preserved
PAR
       061220 02213500 00200100 TASK   <BRUT0 >
BRU - Completed
>CON DISPLAY ATTRIBUTES FOR SYSTEM
CON -- No device name matches select string "SYSTEM"
SYS
PDP-11/84, EIS,UNIBUS_Map,D-Space,Cache,FPP,
Clock=KW11-L, $TKPS=50., $TTPRM=000002, Cache_control=000001
For RL11, I implemented a variant of the RLV211 controller (QBus) - the standard drivers themselves choose the correct option. I don’t plan to implement MSCP yet, so I don’t know how it will be there. The RH70 controller will also be emulated. Later :)
As far as I know RSX-11M Plus (starting from Version 2.1) checks if the machine has unibus mapping registers and then uses UMR for controllers that normally support only 18-bit. Even on Q-Bus machines. And a nice side effect of Version 2.1 is that when they encounter a RH controller with a Massbus Address Extension then they deactivate the UMR for RH controllers and use 22-bit addressing, so you could use a "RH70" on a Q-Bus machine (e.g. the Emulex SC03 ESDI Controller).
And since all this is implemented in one FPGA chip, addresses are broadcast only for UNIBUS controllers :)
How do you activate the mapping? Normally you would need the /MAP output of the DCJ11 which is Bit 5 of MMR3?
