hunterjwizzard
- Joined
- Mar 20, 2020
- Messages
- 2,815
I plan to use this machine chiefly under DOS, but I wanted to have windows95 installed as well because reasons. Since I already have a bootable dos 7.1 install present I did what I usually do for installing windows: copied the folder over to the drive, then ran setup from DOS. I do this regularly on windows 98 but have never installed 95.
Got this error:
Error SU0013
Setup could not create files on your startup drive and cannot set up Windows.
If you have HPFS or Windows NT file system, you must create an MS-DOS Boot Partition. If you have LANtastic server or SuperStor compression, disable it before running Setup. See Setup.TXT on Setup Disk 1 or the Windows CR-ROM.
Got this error:
Error SU0013
