The upper right is an Adtek MP-85, with an 8085 CPU. It's not too far off from a clone of the NEC TK-85 (as you can probably guess from the very similar keypad), though it has only six digits on the display rather than eight, and uses a dedicated chip to run the display rather than DMA from main memory. I've not really played with it much yet, though I intend to disassemble the ROM soon, which should be interesting to compare with the TK-85.Been wanting an NEC trainer for awhile! What are the trainers on the right?
The lower right is a Toshiba EX-80, which is a fairly old (looks to be '70s) trainer board that's interestingly different from the NEC TK-80. That one needs a fair amount of work before it will be running again. (As does my TK-80 itself, actually.)
As for disassembling ROMs, I was being a bit facetious, but it's easier than you probably think, and an excellent way to learn assembly language.
