Mochatea396
Good evening fellow members,
I recently got into burning ISO files and I've been coming across a lot of BIN files in my downloads, and I need some clarification on the procedure for converting these files so I can burn them. I'm not sure if I'm doing it correctly. To start off, all the downloads have both a bin file and a small cue file. (usually 1K). I'm using ISObuster and it will only let me import either or, not both. Which makes sense. (I have only general knowledge of the function of these files) If I import the bin file, it tells me the size of the output file. If I import the cue file, the output file is smaller than the bin files output. But I see what it imported is the same. Nevertheless, my question is should I be importing the bin file or the cue file for the conversion. I've converted a few using the bin file, and provided I didn't have other compatibility issues with the OS, the disc seemed to work. Once the ISO is made, I'm using Nero to burn it.
Thanks
Thanks
