Are you working on integrating support for these boards in XTIDE Universal BIOS?
I've looked at the source; it looks like it should be possible, but either way the code can be made to go faster.
What is the difference between the Standard and Fast transfer modes? As far as I can tell (and I might be wrong on this, reading the datasheet makes me wish google had an engrish translator), the CH375 can only do 8-bit transfers (via Base+0) so how would Fast mode work?
Same trick as XT-CF series use for BIU mode. Shift the address lines, or line in this case, left one and we can use rep insw on V20+.
Thanks, updated.the wiki page refers to both 360h and 260h. I guess this is a typo?
Considering these boards could be useful in a wide range of machines (I'm thinking from XT to AT machines, perhaps all the way up to Pentium class) maybe it would be worth adding more options for ROM and I/O port addresses?
Yes possibly, and also ditching all the THT components for a rev.2 most likley. Keep the ideas coming!
Also, as far as I can tell, the CH375 supports more than one drive. Has anyone tried using a USB-hub with multiple drives? I don't think the BIOS supports that but the driver might? I haven't checked.
Hopefully some beta testers will try for us
