awewsomegamer
- Joined
- Mar 24, 2026
- Messages
- 29
Hello, I've had this monitor for nearly two years now, over that time the image has severely degraded to the point where now nothing is displayed.
The problem, randomly varying brightness/contrast, was barely noticeable at first, and the picture looked completely fine asides from geometric issues (see Picture_in_June_2024.mp4).
I began looking for information on how I could fix this problem, ending up opening the CRT (whilst off and discharged) and replacing a nasty looking capacitor (C525).
However, I found no useful information about this monitor, nor any of its major components (tube, flyback, vertical oscillator), online.
Over the course of one year the picture degraded so much that at maximum brightness and contrast it was still very dim and low contrast (see Picture_in_July_2025.mp4).
At this point I opened up the CRT again and had another look around. I cleaned all potentiometers, which did not fix the issue, and recapped the video circuitry and neckboard, again this did not fix the issue.
I decided to look into replacing the flyback. Upon searching it up, I found a page from Samsung, https://samsungparts.com/products/2859-116-010, listing it as sold out. I sent them an email asking about if they had specifications for it, but they did not respond.
After a while, I decided to digitize the board so that it would be easier to unravel, which revealed another potential problem area: the trimmer resistors near the brightness knob (VR501 and VR503).
From VR501 I could get a stable reading between pins 1 and 2 (~128 kOhm), turning it all the way towards pin 3 gave a reading of 200 kOhm.
However, VR503 was very different, from the only text on it "B2M", I figured its range was likely 2 MOhm, but I could never get a clear reading from it with the multimeter.
Out of circuit, I hooked my oscilloscope's signal generator to pin 2 (in circuit goes to G4) and a probe to pin 3 (in circuit goes to GND) **.
A very similar pattern emerged to how the picture was behaving: there were long periods of low resistance and intermittent bursts of high resistance to ground.
This was the last possible problem I could diagnose and attempt to fix, otherwise it would probably be an issue with the flyback, or something supplying it.
Since I do not have the skill-set to test if it was an issue with the flyback, if replacing VR503 did not work then I would bring the monitor to a repair shop.
**: In circuit, pin 1 of VR503 goes to G2.
Replacing VR503 with a modern alternative, did not fix the issue. Infact, the monitor displayed no picture - even if using the original VR503.
I proceeded to drop it off at a local repair shop, with all original parts in circuit (except for the capacitors I replaced earlier; however, I did provide them labelled in a ziplock bag) and an explanation of what I had done.
A couple days ago I picked the monitor up from the repair shop, and was told that the issue was most likely with the flyback, as everything else looked good.
Would anyone happen to know, or has worked with, this monitor, or know of an equivalent flyback transformer?
IMG_1725.jpg: A picture of the front of the monitor
IMG_1727.jpg: A picture of the back of the monitor
IMG_1731.jpg: A picture of the left side of the monitor
IMG_5008.jpg: A picture of the flyback transformer (T502) with the heatsink of the HOT (Q503) to the bottom and the H-width coil to the right (L502)
Picture_in_June_2024.mp4:
Picture_in_July_2025.mp4:
Notice how contrast and brightness appear to change over time. Most prominently with the clouds behind the statues in the middle of the screen.
*Board: Samsung (?) Chassis NO. GCB, 3003-703-910, 94V-0, KC-16
Flyback: Samsung FMC-1245NL (#2859-116-010)
Tube: Samsung 12NBYLAN
Vertical Oscilliator: Samsung KA2130A (2E2)
*: These are all markings on the board, the first one is toward the top of the circuit by the power switch and the rest are all bunched around T502.
Here is a link to a repository with my attempts to reverse engineer the board: https://github.com/awewsomegamer/Amdek-V220A, revision three is the latest. Please note I am very much a beginner so there may be some nonsense in these schematics.
