allmacs
When i turn on the motherboard seems to do some request. up until the keyboard is initialized. And then stops for some reason.
I don't hear a start up bong , the screen does not get energized, neither do the floppy drives. The hard drive spots up and seeks . The Keyboard flashes , signaling the boot up phase, but that is all
There is a ATS model 116 installed that had a bit of corrosion from the clock battery , I assume the dip switches to be set correctly as they are glued in position.
What do I need to do next to get her to boot?
