Mr. Perfect
- Joined
- Oct 8, 2025
- Messages
- 8
Hey all, I just snagged a Dell Precision Workstation 210 from a company that shut down and put everything out at the curb. Unfortunately it needs a little help.
First thing I did was open it up and do a visual inspection. Apart from an unholy amount of dust that I cleaned out with a canned air duster, there wasn't any visible damage apart from the rear case fan having a seized bearing. Internals include a 450MHz P2 (and a blanked out second Slot 1), 440BX chipset, 4x128MB 100MHz ECC ram sticks, an AGP 2x slot with a video card called a Fire 1K Pro in it (I'm not familiar with this, some sort of workstation card?), and a bunch of drives. The service tag indicates it was built 2/22/98 (the 2s are amusing).
Next I hooked it up to a monitor, mouse and keyboard. As soon as I plugged in the PSU the PC turned itself on (which I find suspicious). The drives and PSU fan spun up, but with no video, no POST and no beep codes. The front panel lights also lit up, but with the HDD activity light solid on and the power button lit up amber (the manual indicates amber is Sleep mode, On is green). It didn't respond to the power or reset buttons. After pulling the power I unplugged as many peripherals as I could, it was down to just the PSU, MB, CPU, video card and a single stick of RAM. As soon as the power cable was plugged in it did the same thing as the first time. For a third attempt I swapped the RAM stick to one of the others, reseated the CPU and VGA, and pulled the KB and mouse just in case it didn't like one of those. This time it made a tiny squeak with the internal speaker, but was otherwise the same. I unplugged it after that since I was out of ideas and didn't want to risk damaging it.
A day later I gingerly opened the lid on the PSU for a visual inspection. One of the big scary caps on the primary side vented sometime in the past, hard enough to knock the little plastic protection disk off the top. The other primary cap was still sleeved up, so couldn't be seen. Two smaller caps on the secondary side had also burst. That was enough to tell me this PSU was probably no good, so sealed it up and started looking for replacements. Unfortunately the board uses an ATX 24 pin rewired to some bonkers Dell proprietary pinout. Ebay has some of the same part number PSUs, but the options are either $50+ for untested 27-year-old PSUs or $200+ for "working pull" 27-year-old PSUs.
Here are pictures of the pinout. I find it a little odd that it's using an adapter to get from older 20 + 6 pin connectors to the 24pin. Especially since the label on the adapter is from September '98, a good seven months after the manufacture date on the case's tag.
So now for some questions:
- Does this behavior sound like a bad PSU, or something more?
- Can anyone share the Service Manual for the 210? I've found a User Manual online, but it's literally just how to use the system with no repair information.
- Are there 24pin ATX adapters to let me hook up a standard PSU to this board?
- If so, does anyone still make PSUs with a -5v line? The OEM PSU has one, but even my oldest spare PSU does not.
