Al Kossow
Documentation Wizard
* Has anyone succesfully restored and run any of the floppy images for IBM Displaywriter on bitsavers?
The single-sided disks have been tested, the recently added double-sided disks have not.
As Chuck says, you really should be using Imagedisk for testing.
and.. be EXTREMELY careful with the disk that was sent to you. Like I said, no double-sided disk images have been verified
to work and it would be really bad if the one you were given was destroyed.
also, the diagnostic disks require one track to be completely blank, which requires you to bulk-erase the diskette before copying to it.
