Tincanalley
My Supermicro P5STE board has suffered some damage from a leaking battery. It was in storage for a bit of time and seemed to work just fine when I fired it up, other than loss of settings. It ran fine for an hour or so, then the mouse went crazy. It shot all over the screen and at the same time it was clicking on stuff. The only way to exit Windows was to power it off. When I restarted I tried it again and after a few mouse clicks in Windows, it went crazy. I blamed Windows of course, but decided to try a serial mouse. That worked fine. I then reconnected the PS/2 mouse and enabled mouse support in BIOS that enables it for BIOS setup. When I went back into BIOS setup, I got one mouse move and one click before it went crazy. So I concluded it's the PS/2 port on the board. I put it away for a few months to work on other things and when I finally got back to it, I opened it up and found the battery had leaked. I removed it and clean neutralized it with distilled vinegar. I in no way removed all the corrosion as I was noticing traces that might be damaged and I stopped, unsure what to do. Now that I have a little more soldering under my belt, I want to attempt to fix it.
All other functions of the board work perfectly. I could just clean it better, use a serial mouse and call it a day, but I want to repair it. I'm sure the mouse is acting up because of a damaged trace. There are a couple on a bank of ferrite beads as well as a few spots on traces connected to the PS/2 header. I've attached a couple of pics and can post more if needed. In looking at them, do you think this is repairable, and if so, worth the effort to get the mouse back?
