Needed - a good .TD0, or .IMD Image for Superbrain QD - DSDD 48 tpi 5.25"
ldkraemer
Chaffee, MO
I'm needing a good .TD0 or .IMD file for a Superbrain QD - DSDD 48 tpi 5.25"
I have several .TD0 images, but most of them appear to have some corrupt files in
the TD0 images. The Maslin 1995 & 1997 files are the ones I'm trying to access
that appear to be corrupt.
Would there be a previous version available?
Or, can some SuperBrain QD user create a .TD0 file from an actual SB floppy with
lots of files I can access?
libdsk Definition ver 1.54
[sup3]
description = SUP3 Superbrain QD - DSDD 48 tpi 5.25" - 512 x 10
sides = outout
cylinders = 70
heads = 2
secsize = 512
sectors = 10
secbase = 1
Complement=Y
datarate = DD
cpmtools Definition ver 2.21
# SUP3 Superbrain QD - DSDD 48 tpi 5.25" - 512 x 10
diskdef sup3
seclen 512
tracks 70
sectrk 10
blocksize 2048
maxdir 64
skew 2
boottrk 2
# data should be complemented
os 2.2
end
Thanks.
Larry
Chuck(G),
THANKS! I'll take anything you have available. At least it will be something to test with that is known to be a good image.
The ones in the Maslin archive (1995 & 1997) appear to be corrupt. I can't get 22DISK to extract a valid file either. So, the Images
have to be corrupt. I was trying QD-UTILS.TD0. It appears to have a valid directory but the files are corrupt after about half way
through the directory.
Thanks.
Larry
Well, here's a bootable image for a QD. Haven't looked at the files, though.
This came from the big stack of "S" floppies. It made me wonder about whatever happened to all of the Shelton/Smart Alec/Sanco/Sorbus/Systel/Signetics/Sperry...etc. machines? By numbers, the Smart Alec was rivaled only by the Sanyo and Sharp systems in popularity.
  • SUPQD.ZIP
Chuck,
Thanks for that file. It proves to me that the QD-UTILS.TD0 image has some corrupt files in the image. I don't know how it
happened, but I can't extract the last half those files correctly, and neither can 22DISK.
Your SUPERQD.IMD file is easily accessed:
00 11776 nsweep.com 01 02 03 04 05 06
00 768 news1. 07
00 1408 news10. 08
00 896 news2. 09
00 1024 news3. 0a
00 1024 news4. 0b
00 896 news5. 0c
00 896 news6. 0d
00 1152 news7. 0e
00 1280 news8. 0f
00 1280 news9. 10
00 1024 welcome. 11
00 22400 qdiibios.asm 12 13 14 15 16 17 18 19 1a 1b 1c
00 1024 sb.asm 1d
00 32768 mast.cat 1e 1f 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d
00 59136 mast.cat 2e 2f 30 31 32 33 34 35 36 37 38 39 3a
and the files are all sane, as I can view and edit all the text, .cat, and .asm files.
THANKS.
Larry
Chuck(G),
I doubt if you will have any of the following TD0 images/files, but here is the list of .TD0's that I'm having trouble with:
(The first three .TD0's I'd really like to get all files extracted. They are from the Maslin Archive 95 & 97 archives)
qd-bios4.td0
qdhdbios.td0
qd-utils.td0
vpu30enh.td0
vpu30non.td0
vpu30nrm.td0
vpu-comm.td0
qd-zcpr3.td0
watstar.td0
csr-comm.td0
csr30non.td0
csr30enh.td0
sbrain32.td0
csr30nrm.td0
All of these show version 1.5 in the .TD0 file (5th byte is 15), but I don't think that is the proper version of Teledisk
that created the .TD0 images.
Thanks.
Larry
I tested all td0-files from the intertec folder with TDCHECK and is told me that all files are OK and teledisk version 2.1 was used to generate the files.
I use these files:
http://oldcomputers.dyndns.org/public/pub/archiv/maslin/masl-dsk/images-97/intertec/index.html
http://oldcomputers.dyndns.org/public/pub/archiv/maslin/software/util/tdcheck.exe
I copied the files to a OS/2 MSDOS folder ...
Here my logfile:
X---------------------------------------------------------------X
TDCheck TeleDisk File Checker, Version 2.20
Sydex Copyright 1993. All Rights Reserved.
-- Checking d:\dosprg\testtd0\CSR-COMM.TD0...
Produced with version 2.1
New Advanced data compression was used.
All sectors were copied.
One side was checked.
Source was 5¬" low-density MFM.
This file was created on November 27, 1990 at 19:52:32
Intertec Compustar VPU30 Non-enhanced system
Includes Modem705, and Kermit comm programs
Reading Track 0, Side 0, 10 Sectors
Reading Track 1, Side 0, 10 Sectors
Reading Track 2, Side 0, 10 Sectors
Reading Track 3, Side 0, 10 Sectors
Reading Track 4, Side 0, 10 Sectors
Reading Track 5, Side 0, 10 Sectors
Reading Track 6, Side 0, 10 Sectors
Reading Track 7, Side 0, 10 Sectors
Reading Track 8, Side 0, 10 Sectors
Reading Track 9, Side 0, 10 Sectors
Reading Track 10, Side 0, 10 Sectors
Reading Track 11, Side 0, 10 Sectors
Reading Track 12, Side 0, 10 Sectors
Reading Track 13, Side 0, 10 Sectors
Reading Track 14, Side 0, 10 Sectors
Reading Track 15, Side 0, 10 Sectors
Reading Track 16, Side 0, 10 Sectors
Reading Track 17, Side 0, 10 Sectors
Reading Track 18, Side 0, 10 Sectors
Reading Track 19, Side 0, 10 Sectors
Reading Track 20, Side 0, 10 Sectors
Reading Track 21, Side 0, 10 Sectors
Reading Track 22, Side 0, 10 Sectors
Reading Track 23, Side 0, 10 Sectors
Reading Track 24, Side 0, 10 Sectors
Reading Track 25, Side 0, 10 Sectors
Reading Track 26, Side 0, 10 Sectors
Reading Track 27, Side 0, 10 Sectors
Reading Track 28, Side 0, 10 Sectors
Reading Track 29, Side 0, 10 Sectors
Reading Track 30, Side 0, 10 Sectors
Reading Track 31, Side 0, 10 Sectors
Reading Track 32, Side 0, 10 Sectors
Reading Track 33, Side 0, 10 Sectors
Reading Track 34, Side 0, 10 Sectors
Reading Track 35, Side 0, 10 Sectors
Reading Track 36, Side 0, 10 Sectors
Reading Track 37, Side 0, 10 Sectors
Reading Track 38, Side 0, 10 Sectors
Reading Track 39, Side 0, 10 Sectors
Reading Track 40, Side 0, 1 Sectors
Reading Track 41, Side 0, 1 Sectors
*** CSR-COMM.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\CSR30ENH.TD0...
This file was created on November 27, 1990 at 19:08:48
Intertec Compustar VPU30 Enhanced Standalone System
Reading Track 35, Side 0, 1 Sectors
Reading Track 36, Side 0, 1 Sectors
Reading Track 37, Side 0, 1 Sectors
Reading Track 38, Side 0, 1 Sectors
Reading Track 39, Side 0, 1 Sectors
*** CSR30ENH.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\CSR30NON.TD0...
This file was created on November 27, 1990 at 19:13:50
Intertec Compustar VPU30 Non-enhanced Standalone System
*** CSR30NON.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\CSR30NRM.TD0...
Normal data compression was used.
Both sides were checked.
This file was created on September 30, 1990 at 16:11:30
Compustar Non-Enhanced VPU-30
Reading Track 0, Side 0, 11 Sectors
Reading Track 0, Side 1, 11 Sectors
Reading Track 1, Side 0, 11 Sectors
Reading Track 1, Side 1, 11 Sectors
Reading Track 2, Side 1, 11 Sectors
Reading Track 3, Side 1, 11 Sectors
Reading Track 4, Side 1, 11 Sectors
Reading Track 5, Side 1, 11 Sectors
Reading Track 6, Side 1, 11 Sectors
Reading Track 7, Side 1, 11 Sectors
Reading Track 8, Side 1, 11 Sectors
Reading Track 9, Side 1, 11 Sectors
Reading Track 10, Side 1, 11 Sectors
Reading Track 11, Side 1, 11 Sectors
Reading Track 12, Side 1, 11 Sectors
Reading Track 13, Side 1, 11 Sectors
Reading Track 14, Side 1, 11 Sectors
Reading Track 15, Side 1, 11 Sectors
Reading Track 16, Side 1, 11 Sectors
Reading Track 17, Side 1, 11 Sectors
Reading Track 18, Side 1, 11 Sectors
Reading Track 19, Side 1, 11 Sectors
Reading Track 20, Side 1, 11 Sectors
Reading Track 21, Side 0, 11 Sectors
Reading Track 21, Side 1, 11 Sectors
Reading Track 22, Side 1, 11 Sectors
Reading Track 23, Side 1, 11 Sectors
Reading Track 24, Side 1, 11 Sectors
Reading Track 25, Side 1, 11 Sectors
Reading Track 26, Side 1, 11 Sectors
Reading Track 27, Side 1, 11 Sectors
Reading Track 28, Side 0, 11 Sectors
Reading Track 28, Side 1, 11 Sectors
Reading Track 29, Side 0, 11 Sectors
Reading Track 29, Side 1, 11 Sectors
Reading Track 30, Side 0, 11 Sectors
Reading Track 30, Side 1, 11 Sectors
Reading Track 31, Side 0, 11 Sectors
Reading Track 31, Side 1, 11 Sectors
Reading Track 32, Side 0, 11 Sectors
Reading Track 32, Side 1, 11 Sectors
Reading Track 33, Side 0, 11 Sectors
Reading Track 33, Side 1, 11 Sectors
Reading Track 34, Side 0, 11 Sectors
Reading Track 34, Side 1, 11 Sectors
Reading Track 35, Side 1, 1 Sectors
Reading Track 36, Side 1, 1 Sectors
Reading Track 37, Side 1, 1 Sectors
Reading Track 38, Side 1, 1 Sectors
Reading Track 39, Side 1, 1 Sectors
Reading Track 40, Side 1, 1 Sectors
Reading Track 41, Side 1, 1 Sectors
*** CSR30NRM.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\QD-BIOS4.TD0...
This file was created on November 27, 1990 at 21:33:37
Intertec Superbrain BIOSes
64K Superbrain V40BIOS
CP/M 2.2 BDOS Z80CCP
Reading Track 0, Side 1, 10 Sectors
Reading Track 1, Side 1, 10 Sectors
Reading Track 2, Side 1, 10 Sectors
Reading Track 3, Side 1, 10 Sectors
Reading Track 4, Side 1, 10 Sectors
Reading Track 5, Side 1, 10 Sectors
Reading Track 6, Side 1, 10 Sectors
Reading Track 7, Side 1, 10 Sectors
Reading Track 8, Side 1, 10 Sectors
Reading Track 9, Side 1, 10 Sectors
Reading Track 10, Side 1, 10 Sectors
Reading Track 11, Side 1, 10 Sectors
Reading Track 12, Side 1, 10 Sectors
Reading Track 13, Side 1, 10 Sectors
Reading Track 14, Side 1, 10 Sectors
Reading Track 15, Side 1, 10 Sectors
Reading Track 16, Side 1, 10 Sectors
Reading Track 17, Side 1, 10 Sectors
Reading Track 18, Side 1, 10 Sectors
Reading Track 19, Side 1, 10 Sectors
Reading Track 20, Side 1, 10 Sectors
Reading Track 21, Side 1, 10 Sectors
Reading Track 22, Side 1, 10 Sectors
Reading Track 23, Side 1, 10 Sectors
Reading Track 24, Side 1, 10 Sectors
Reading Track 25, Side 1, 10 Sectors
Reading Track 26, Side 1, 10 Sectors
Reading Track 27, Side 1, 10 Sectors
Reading Track 28, Side 1, 10 Sectors
Reading Track 29, Side 1, 10 Sectors
Reading Track 30, Side 1, 10 Sectors
Reading Track 31, Side 1, 10 Sectors
Reading Track 32, Side 1, 10 Sectors
Reading Track 33, Side 1, 10 Sectors
Reading Track 34, Side 1, 10 Sectors
Reading Track 35, Side 1, 10 Sectors
Reading Track 36, Side 1, 10 Sectors
Reading Track 37, Side 1, 10 Sectors
Reading Track 38, Side 1, 10 Sectors
Reading Track 39, Side 1, 10 Sectors
*** QD-BIOS4.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\QD-UTILS.TD0...
This file was created on November 27, 1990 at 20:27:00
Intertec Superbrain QD DOS 3.0 w/hard disk
*** QD-UTILS.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\QD-ZCPR3.TD0...
This file was created on November 27, 1990 at 21:16:24
Intertec Superbrain QD - ZCPR BIOS and source
64K Superbrain QD DOS 3.2
CP/M 2.2 BDOS & CCP
*** QD-ZCPR3.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\QDHDBIOS.TD0...
This file was created on November 27, 1990 at 21:00:41
Intertec Superbrain hard disk BIOSes
64K Superbrain QD DOS 3.2 w/hard disk
CP/M 2.2 BDOS Z80 CCP
*** QDHDBIOS.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\SBRAIN32.TD0...
This file was created on October 10, 1990 at 21:25:21
Superbrain CP/M 2.2 rev 3.2 64K memory SSDD 35 track
*** SBRAIN32.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\VPU-COMM.TD0...
This file was created on December 11, 1990 at 9:38:37
CompuStar VPU-30 CP/M 2.2 non-enhanced
Includes Kermit and Modem705
Reading Track 35, Side 1, 11 Sectors
Reading Track 36, Side 1, 11 Sectors
Reading Track 37, Side 1, 11 Sectors
Reading Track 38, Side 1, 11 Sectors
Reading Track 39, Side 1, 11 Sectors
Reading Track 40, Side 1, 11 Sectors
Reading Track 41, Side 1, 11 Sectors
*** VPU-COMM.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\VPU30ENH.TD0...
This file was created on December 11, 1990 at 12:55:08
Intertec CompuStar VPU-30 CP/M 2.2 enhanced stand-alone system
Using CS30CPM.COM
*** VPU30ENH.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\VPU30NON.TD0...
This file was created on December 11, 1990 at 12:34:19
Intertec CompuStar VPU-30 CP/M 2.2 non-enhanced stand-alone system
Using CS30CPM.COM
*** VPU30NON.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\VPU30NRM.TD0...
This file was created on December 11, 1990 at 12:21:13
using 6QCPM5-1.COM
*** VPU30NRM.TD0 Checks OK ***
-- Checking d:\dosprg\testtd0\WATSTAR.TD0...
This file was created on November 27, 1990 at 20:43:54
Intertec *Watstar source code for Compustar(?)
64K Superbrain QD DOS 3.0
CP/M 2.2 BDOS & CCP
*** WATSTAR.TD0 Checks OK ***
14 file(s) processed.
fritzeflink,
Thanks for that information. I'll try an earlier version of Teledisk to see if that works.
I finally used Ver 2.16, and got the TD0 images wrote, and accessed with 22DISK & cpmtools with libdsk 1.5.4).
Larry.
Are any of these images known good for 50 Hz machines?
Seems the CP/M BIOS is resetting the screen to 60Hz at bootup (probably because one OUT controls several lines only one of which is the 50/60Hz switch, so whenever it tries to set another line it's assuming 60 Hz and wrecking the 50Hz display).
[Edit: Forget I said that. There is a configuration facility that allows you to set the screen refresh rate on the boot disk.]
JonB
Rather than hacking the system tracks to alter the flag holding the 60/50hz frequency, you can use the CONFIGUR program on one of the boot disks.
The first option is to alter the frequency.
Hope you find your "I"
StephenM
Quick update on the Maslin Superbrain disk images that I got from Larry (he'd extracted all the files and checked them for me and StephenM). Most of them are bootable and there are various BIOSes present:
  • CBOOT: Compustar Model 30 v0.2 - 35 tracks, DS
  • CSR30ENH: Compustar Model 30 v0.2 - 42 tracks, SS
  • CSR30NON: No boot track - 42 tracks, SS
  • CSR-COMM: Compustar Model 30 v0.3 - 40 tracks, DS
  • CSYSGEN: Compustar Model 30 v0.2 - 35 tracks, DS
  • CUTILS: Compustar Model 30 v0.2 - 35 tracks, DS
  • QDBIOS4: BIOS v4.0x17 (UNRELEASED!) - 40 tracks, DS
  • QDHDBIOS: CMC QD Super5 DOS v1.1 - 40 tracks, DS
  • QD-UTILS: CMC Superbrain / Targa DOS v1.0 - 40 tracks, DS
  • QD-ZCPR3: ZCPR - 40 tracks, DS
  • ZMAST: ZCPR OS - 40 tracks, DS
  • SBRAIN32: 64K Superbrain DOS v3.0 - 40 tracks, DS
The drive geometry is as reported by the HxC emulator software. None of these images run properly on a 50Hz machine, and quite a few of them set the CRT8002 to a graphic character set. To correct this on a 50 Hz machine like mine, a short program that restores the CRT settings after boot by doing OUT 68,3 can be run.
I'm pretty sure that the image with 42 tracks is corrupt in some way, but its content can be read on the Superbrain.
Interestingly, the QDHDBIOS image has various HDD BIOS code and information, including the ACT controller.
Cheers
JonB
