Southern Europe New items for vintage computer: High Performance Low Cost hard disk device for Atari ST/E family
Covers: Italy, Spain, Greece, Portugal, Serbia, Croatia, Bosnia and Herzegovina, Albania, North Macedonia, Slovenia, Montenegro, Malta, Andorra, San Marino and the Vatican.
masteries
Madrid, Spain, Europe
Delivery Options
International Shipping
A High Performance Low Cost Hard Disk interface compatible with Atari ST family computers,
read is around 1 MB/s, and write is 700 KB/s
Performance with a 1 GB SD card:
Some videos:
How to use many partitions, up to 7 GB total; in 14 partitions of 512 MB
How to start using it correctly
A video from an user:
The hard disk image (DOS & TOS compatible, readable on Windows)
You can use Win32DiskImager (Windows) in order to write it.
The ST / STE with a hard disk is another world!
price is 36€ + shipment , with tracking number (6.50€ for Spain or 10.50€ for Europe; Australia, Alaska, Canada and Japan 12€; USA - America 11€ )
Lower cost and better SD card compatibility than any Satan disk, and much lower price than UltraSatan.
Its the Atari ST hard disk suitable for the masses,
Addendum,
List of tested micro SD cards:
-Working ones:
Kingston de 8 GB clase 4
Kingston de 4 GB clase 4
Intenso de 8 GB clase 4
Intenso de 16 GB clase 6
Intenso de 4 GB clase 10
Intenso de 8 GB clase 10
Kingston de 16 GB clase 10
Sandisk de 16 GB clase 6
Kingston 2GB class ?? (no lo indica; ero es la "reputada" SD-C02G - Probada por Jltursan )
Kingmax 2GB class ?? (sin pistas - Probadas por Jltursan)
Nisu 2GB Class 6 (no tiene marca que la identifique - Probada por Jltursan)
Toshiba 16 GB Class 10 UHS-1 (Una UHS 1 que funciona, probada por Real Larry (AF) )
Tarjetas Mitos 4 GB Class 10 (https://de.aliexpress.com/item/1005002096781542.html, probada por Real Larry (AF) )
Tarjetas Mitos 1 GB (https://de.aliexpress.com/item/1005002096781542.html, tested by Philgood1351fr (EAB) and Masteries )
Intenso de 32 GB clase 10 (Probada por Real Larry (AF) )
Kingston 1 GB (tested by Shaoth)
Kingston 2 GB (tested by Shaoth)
Philips 64 GB UHS-1 A1 V10 Micro SDXC (tested by Shaoth)
Sandisk Extreme Plus 64 GB UHS-3 Micro SDXC (tested by Shaoth)
Samsung Evo Plus 128 GB UHS-3 Micro SDXC (tested by Shaoth)
SanDisk Ultra class 10 16GB (Tested by Synt4x_3rr0r)
64GB Kingston Canvas Select Plus (U1 V10) (Tested by Woogle)
32GB Kingston Canvas Select Plus (Tested by BinaryBrother)
16GB INMSDH16G-100V10 (Tested by Wanman)
Samsung Evo plus 128GB microSD SDXC U3 class 10 A2 (Tested by Bilbobaggins)
-Non working ones:
Cloudisk de 512 MB (tested by Masteries)
Sin marca de 4 GB (Tested by Masteries)
MediaRange de 8 GB clase 10 (tested by Masteries)
Sandisk 32 GB clase 10 UHS-1 (tested by Masteries)
SanDisk 16 GB MicroSDHC UHS-1 (reported by Philgood1351fr (EAB) )
Sandisk 1 GB card non class specified (tested by Masteries)
Tested power sources:
Old Ipod 5V 1A (from the times where Ipod has a mechanical hard disk inside)
Farnell USB power source 5V 2A
Original Raspberry Pi 2/3 5.1V 2.5A power source (tested by Real Larry)
Ipad2 Apple 10w USB psu model no A1357
Flextronics A/12981EA LPS output 5.1 v 2.1 A (tested by Thesofa2)
Eleaf BEK-QC-001 5V 1A charger (Tested by Synt4x_3rr0r)
D-Link I.T.E 5V 1.2A (Tested by Xav2075)
Primark USB Travel Charger :D Model: MDUSB3BKMPRM (Tested by ChaoticBiker)
Apple USB-A charge (Tested by BinaryBrother)
MDY-09-EW (Tested by Flytrap) - EASILY AVAILABLE, AROUND 4 to 5€ -
Ktec 10W Model: KSAPK0110500200HE Output: 5V - 2A (Tested by Glue)
Asda 5.0v/2.4Amp (12.0 Watt) Model No: ONA19W1851 PSU (Tested by Bilbobaggins)
Update
from 15 May 2022 the common problem with many power sources is solved,
The problem was the usage of micro USB port for powering;
now each hard disk unit comes with an attached and soldered USB cable.
Can I use this on a Stacy with the internal acsi port?
As far I remember, there is another user that bought one for a Stacy; but you will need to manage to connect the Stacy ACSI port to the handmade DB19 pinout.
From the user report, it works well once you managed to plug it inside.
As a modern replacement to the original internal hard disk.
From photographs I saw Stacy also has external ACSI port.
Also you will need to take into account that this high performance low cost hard disk operates in master mode,
no more hard disk units can be daisy chained.
How well would this work in a non-STe machine, like a STm?
Excuse the delay,
Yes, the device operates well in standard ST machines, also MegaST and TT ones.
There are units in stock!
Current price per unit, including an attache USB power wire, is 37€ (I can´t edit the first post).
Material pricing and shipment is continously rising... that is very annoying :(
