NeXT
I picked this up from consignment at VCF West on a gamble that it wasn't too bad. It needed a full strip and clean because the carrying bag it was in had been dumping sticky powdery foam everywhere but I think other than the battery eliminator/PSU and the lid it's all here. Opening it up found no co-processor or external video board (whatever) but it had a memory expansion and internal ROMs for GRiD-OS 3.1.5 and MS-DOS 3.2 and GRiDMaster. It also has one of the 26 pin JVC hard drives in an unknown condition (not the drop sensor wasn't tripped) and a gas plasma display that doesn't look broken or burned. The 3.6v battery also looks good, but I snipped it out anyways.
The main issue now is I can't get any life out of it. I'm feeding it 16v DC from my bench supply through the barrel jack on the back (center pin positive) but that tops out at 3A. I get a blink of the red LED on the screen, a hiss from the DC-DC supply and nothing else beyond the bench supply overshoots 3A, drops the voltage and then stabilizes with a 500ma draw. No drive spin-up, nadda.
Poking around I can see +5, +12 and +33 for the screen, so it's doing something but I cannot tell what else it wants. I unplugged the hard drive and that changed nothing. I unplugged the screen to see if it would at least give a POST beep blind but still, nothing.
I know the battery eliminator/PSU brick needs a recap but what about the internal DC/DC module? It didn't look visibly leaky, but I'm not a GRiD expert weather or not these in particular are a problem.
