new VI clone for CP/M 2.2 and 3.0
I used the HTC linux port from https://github.com/ogdenpm/hitech and compiled hvi.com with:
htc -V -O hvi.c gap.c term.c screen.c emove.c edit.c erepeat.c ex.c
giving
-rw-rw-r-- 1 horo horo 38012 30. Apr 20:04 hvi.com
z88dk sdcc: I found that the sdcccall(1) convention (which passes parameters in registers instead of on the stack IX/IY-indexed) gives pretty good code, if kept to a few parameters. I still work on the z80-adaptation at https://github.com/ravn/llvm-z80 but even at the current embryonic stage it generates better code than sdcc. The llvm backend in z88dk is still very experimental and didn't generate as good code so I didn't use it much.
I could probably come up with workable code for things like strlen, fopen, etc. These are fairly well known and well documented routines, and there might even be examples available on-line. BUT, what the heck does _iob do? Is it something that is only found in the HiTech package? Of course, this all assumes that I can figure out how to generate a ".a" archive that XGCC will work with.
All the functions listed are parts of the standard C library. I don't know if there is one for CP/M-68K; if not, one would have to be written or ported. _iob is the table of open stdio files, starting with stdin, stdout and stderr. So _iob[0] is stdin, _iob[1] is stdout, _iob[2] is stderr.
Thanks John, my iobyte was just a "wag" (wild assed guess)!
giving
oh cool. I was looking for the linux port. This will help with my iterations. I'm still plugging away at refactoring the stdlib out of the app. Thanks for this.
Not so much of a "wag" as you might think. The iobyte could have a great deal to do with the definition of stdin, stdout, and stderr!
A related question: is it possible to force HiTech C to generate 8080 code only? Or any other of the popular C compilers of the time?
ACK generates 8080 code. Also, the FUZIX compiler (which is a recent development) can target 8080, 8085 and Z80. Both are cross-compilers.
The _iob buffer contains the file definition area (8 bytes / file)
In the case of HiTech C , buffers for 5 files are quite enough
; Offsets of things in the _iob structure
ptr equ 0 ; pointer to next byte
cnt equ 2 ; number of bytes left
base equ 4 ; beginning of buffer
flag equ 6 ; flag bits
file equ 7 ; file number
; The bit numbers of the flags in flag
_IOREAD_BIT equ 0
_IOWRT_BIT equ 1
_IONBF_BIT equ 2
_IOMYBUF_BIT equ 3
_IOEOF_BIT equ 4
_IOERR_BIT equ 5
_IOSTRG_BIT equ 6
_IOBINARY_BIT equ 7
Please, study the Z80 assembler source files named "lib*.as" to be found in my customised HiTech C compiler... you will find there all the necessary LIBC.LIB modules( strings, file I/O, ...), implemented as Z80 assembler files.
Ladislau
If you build HVI on a CP/M machine, you do not need to worry about these ".a" archives.
I develop my Z80 software projects on a outstanding 25MHz Z80 CP/M machine (built by Bill Shen "plasmo"), and I am quite content with its processing speed.
Of course, I use my customized HiTech C toolset, in order to be able to use larger C and assembler source files...
Once again, as you, I encountered the same obstacle (too big final executable) and I was constrained to build my "custom" LIBC, by replacing all the necessary library modules with Z80 assembler files, assembled and added in the final LINK command.
Ladislau
OK - I've been busy and have a completely different build that I'm calling ZVI. In this iteration, I wanted to test if I could use the horsepower of a modern computer with a more modern compiler/assembler toolchain to optimize the binary size. For this version the source has been updated to compile with Z88DK/SDCC and I've tried to eliminate all dependencies on the STDLIB of that toolchain. This has brought the binary down to ~34k. I've also added true large file support. Please let me know if this works better for you all, if you have any suggestions, and/or if you run into any issues. The repo is here: https://github.com/tachijuan/zvi
I downloaded the code from the zvi github site. ZVI.COM works OK with my 20 MHz SBC. It's a little slow, but still quite usable. Kudos that the arrow keys now work! Great piece of work!! I have not tried to build my own version yet ... just used the .COM file included with the code.
Thanks.
edit: works even better on my 24 MHz Z80 SBC!!!
I downloaded HVI.COM and uploaded it to a real Z80 CP/M machine which has 51K of TPA below the BDOS. I get a "hvi: out of memory" error when I try to run HVI. Does HVI need to be compiled on the target machine? Do I need any HiTech-C runtime files on the disk to support the program?
Mike D
Mike - I just posted version 2.0 of HVI on GitHub. It's ~11K smaller and should work in your environment. Give it a go and let me know how it goes for you.
Thanks,
Juan
Nice! Today I added ANSI support to my fZ80, HVI.COM works on CP/M, and runs on MP/M II 2.1 maybe with issues. I have a bunch of ANSI sequence issues I have to fix before I can know. When I do I'll bang on it and get back to you.
Thanks,
Juan
Juan,
HVI now runs on my Z80 CP/M 2.2 machine and no longer gets the out of memory error. However, several primary commands don't seem to work properly. Both I and i immediately enter an endless loop of inserting spaces rapidly, and yet, I can type in new characters while it's busy inserting spaces. Paging forward and backward takes about 5 seconds before the page starts to redraw. I noticed that cw, dw, etc., don't work - i assume those modifiers aren't implemented. If instead I individually delete characters, it takes 2-3 seconds per character deleted (more time the closer the cursor is to the top of the screen). Looks like running with reasonable response time on a real 2MHz or 4Mhz machine may require a more optimized solution coded in assembly language.
Have you every tried WordMaster (the predecessor to WordStar)? John did an excellent job getting reasonable response time in a full screen editor on a 2MHz 8080 or Z80 machine. I'd like to create a version of vi that has performance similar to WordMaster.
Mike D
Juan,
Mike D
Thanks for testing. That's interesting. I'll dig into the input loop to see what might be causing this. It'll be a bit of time before I can work on this again. Sit tight.
I have not had an opportunity to try HVI.COM, but I'm happy to hear about ANSI support in fZ80. I assume it's a subset?
I tried to include all I could find. I've left out keyboard and other such. Colors and modes are way off; colors not yet mapped. Modes mostly not possible (dim, strikethrough) but those hopefully aren't critical.
I used this: https://gist.github.com/ConnerWill/d4b6c776b509add763e17f9f113fd25b
It's horribly buggy -- hvi runs but the screen is a mess, but consistent. It just needs debug time and I'm in the middle of getting all the hardware together for 25 new machines; boards and cabinets arrive next week. Sans a real test program, I work up a hideous kludge to halt (firmware) after each hvi ANSI command and track command vs. result. Probably I can get most of it fixed in a day.
It's interesting how many H19 sequences map to ANSI, and VT100. Implementation was to catch the '[' and turn the states that followed into recursive calls to H19Out() using the H19 states.
Oh -- no H19 vs ANSI mode needed -- only one command conflicted! ESC M. To resolve that, a heuristic flag set positively-ANSI for each valid ESC [ x y... sequence, and set positively-H19 for ESC Y and some other. Then ESC M decides via that flag. "Should work" lol, if not, a MODE via VGA.COM or something.
Juan,
Mike D
Mike -
I just posted version 2.3. There's been a bunch of work done to verify that all commands work and performance on slower CPU's should be much better. I've also improved the screen refresh logic to accommodate slower terminals. Let me know how all this plays out in your machine.
What are the differences between HVI and ZVI?
HVI is my current most feature rich and stablest version. I'll match capabilities with ZVI in a little while. The biggest difference is that ZVI is built to be cross-compiled with Z88DK and HVI is built to be compilable (and is) within CP/M with the HiTech-C compiler.
