paul
This is the common 3-ft cable with 50-pin high-density connectors that nearly every mid-'90s workstation uses on the narrow, single-ended SCSI bus.
They must have finally figured out that they are obsolete and have over 300 in stock. The minimum order quantity is (1) on the US site and (200) on NZ and AUS. But you can phone the order in to buy just one, ask for Lily.
USA http://www.newark.com/multicomp/spc10516/computer-cable-scsi-3ft-gray/dp/19C8365
NZ http://nz.element14.com/multicomp/spc10516/computer-cable-scsi-3ft-gray/dp/4511920
AUS http://au.element14.com/webapp/wcs/...01&langId=43&productId=64648058&storeId=10184
