Desperado
- Joined
- Nov 25, 2017
- Messages
- 6,827
i connected black lead on pin3 of connector!2 VDC on pins 2/4 doesn't sound correct though. How are you measuring this voltage? Where have you connected your multimeter negative (black) lead to?
Disconnected!Also, are these measurements with J8 plugged into the main logic board or disconnected from it?
17,2 VWhat about measuring the AC voltage between J8 pins 8 and 9? There is a separate transformer winding for other voltages.
Without 6502 i see this picture and i haven t flickering chars.this should be this dave:
Ok i have waveform signal on every BAn lines of B3 and C3 (with Nop). With Nop inserted i see again some flickering charsOk, so I would go with the NOP generator next and test the buffered address lines (BAn) from B3 and C3 and the address decoder D2.
Yes seems to be ok!Did you check for the correct frequencies and wave shapes on the BAn signals?
Correct, i have signal on pins 1 to 17, no signal on pin 12!I would check pins 1 to 17 (noting there is no pin 12 - this is GND).
