I wish I seen this but I still might need one if the one I just bought doesn't work but I just order this one. https://www.ebay.com/itm/Nice-Clean...JobZGWt7cy08tGxTnL842JFTEbs%3D&orig_cvip=true Someone lone me the money.Where do you live?
I have some Coco 2's here. You can have one if you want to come get it. But, I'm not sure I can ship it to you for under $20.00...
They are all working, BTW. Then you can put you $20.00 towards a cassette cable and a tape recorder for it.
They don't have switch box and my TV is a Samsung LED and it only has hdmi, rgb and cable connector. So I won't have no way to test it when I get it.The plug on the back of the CoCo is an RCA phono jack, and it originally connected to the VHF antenna input of a television using a little switch box that came with the computer. The switch box stuck on the back of the TV and connected to its antenna screw terminals, and then a cable with an RCA phono plug at each end connected between the CoCo and the switch box.
I can't win from losing an anything. All the TV in my house are 2 year or newer.This is a picture of a Coleco Adam, but it's the same kind of switch box and cable that the Color Computer used:
When I get it I will hook a cable wire to the TV and put it on ch3 or ch4 and fine away to hook it up to the Coco. Up to 2 month ago I could watch TV with just the cable wire and then they change it now I need a cable box and I hate that.
One more question do they make a RCA plug and the other end cable connector?
