Kanpai
- Joined
- May 23, 2019
- Messages
- 10
Hi everyone,
I recently build a CGA Redux by Hkz with an old style composite out configuration. I tested the card in an IBM 5155 connecting the internal CRT to the card. When I turn the machine on I notice a bright horizontal line (probably 1 cm heigh) on the CRT for a second or two (out of sync or horizontal collapse?). Afterwards, I get a normal image. RGBI output on an 5153 and external composite out over a composite to VGA adapter look normal.
Furthermore, from a blog entry by Reenigne I gather that old style composite will not provide the best image on a monochrome CRT like the one in the 5155 to beginn with. In short, old style composite generates less shades of grey.
My plan for the card is to added a daughterboard which will provide new style composite out over an internal header, while the card itself will provide old style composite out over the RCA jack. In theory this should provide a good grey scaled image on the internal CRT and old style composite externally for games that were optimised for old style composite:
Note: the position of the RCA jack on the PCB will interfer with the chassis of a 5150/5160. If you would like to build your own card you may want to move the jack further down.
Has anyone tried a CGA card with an old style composite out in a 5155 before and can confirm my observations? Did IBM actually ship 5155's with old style composite out or only with CGA cards in the new style configuration? I am not sure if old style composite in general or my card configuration (use of standard TTL IC's instead of LS) might cause this bright horizontal line on start up and eventually damage the CRT in the long term.
