Jan de Lange
- Joined
- Jun 20, 2024
- Messages
- 208
We differ from opinion. I think monochrome is more interesting.
| VCF SoCal | TBD, 2027, | Southern CA |
| VCF East | TBD, 2027, | InfoAge, Wall, NJ |
| VCF Latam | TBD, 2027, | Bahía Blanca, Argentina |
| VCF Pac. NW | TBD , 2027, | Tukwila, WA |
| VCF Southwest | TBD, 2027, | Westin Dallas Fort Worth Airport |
Question: does the M24 monitor have the same slow phosphor as the M19? Or is it totally incompatible?
How can such be connected to Olivetti PCs (or even to a my M24 PCBs)?Hunt for MDA/Hercules monitors, ....
No. The M24 videofrequency is tooo fast for M19 monitor, and that's valid for any text and graphics mode of M24. And M19 video signal is tooo slow for M24 monitor. M19 video is below of CGA standard, means, slower than 15kHz. Doesn't care if you compare the monochrome MDA-alike monitors or color monitors for M19 and M24. The M19 was made for lowcost with a graphics card which supports very cheap lowcost monitor frequency, with special phospor coating which lightens very long to hide the low refresh rate, otherwise it would flicker. And M24 video timing is beyond standard-CGA, so even a normal fixed frequency CGA monitor won't work on M24, so here you need the original monitor or something multisyncing like NEC, TVM, or modern TFT from that 15khz list which is flexible enough to support something like 24khz as well...I think I get why you're asking, and my answer would be yes - the dithering should work on M24 monitors too.
I am planning to try an MDA CRT monitor hopefully within several weeks (still too busy with other tasks) with the remnants from M24 I acquired.What I never have seen if someone tried to get a real MDA monitor on M24. Maybe it is possible, you need to get the M24 to make the MDA alike video signal, but I have doubts if a standard MDA monitor would be fast enough for M24 video frequency. To switch the M24 to monochrome output you need to let pin 2 and 10 of the connector open while for a color monitor you need to ground both. This pin changes the card's behaviour in some matters, not only it outputs a monochrome (dithered) videosignal, but it also changes some text attribute behaviour.
But all of this really should be discussed in a extra thread, M24 not equal to M19, different model, different specs, different technology, different target customer (low cost versus "better than IBM"). I don't understand that no moderator reacts here, also not on the report button for a separation of topic. Maybe more peoples should report the seapration of topics.
I am not a moderator here, otherwise I would cut out and separate that M24 discussion in a new thread. And I don't want to be moderator, not here and anywhere else, but I ask myself, where they are, and why they don't do anything in such matter, also like 486/pentium topics moving away from XT/286 subforum. That never happens. But this is again offtopic from offtopic.Feel free to create or point to M24 topic.
it was on ebay.Do you have a list of sites where you source them?
Initially I plan to try an MDA monitor.@george how do you intend to make M24 display 18 kHz frequency?
