Original Final Fantasy VIII for PC
hunterjwizzard
I had a hankering to finally finish FF8 for the PC(game I started 23 years ago) using my vintage Pentium II laptop. My original game disks are scratched all to hell but I managed to pull clean rips of them. The disks flat out won't work for playing the game anymore(which is 70% of why I never finished playing it 23 years ago).
My attempts to find a solution are badly hampered by some stupid "remaster" that came out recently. No matter what I search, all I get are ancient forum posts with dead links or modern stuff about the stupid remaster. Anyone got any ideas on how to make this game work?
How have you tried using the rips, a virtual drive, burned to CD-R, both? Also were they ISO rips or something higher fidelity like BIN/CUE?
ISO rips mounted to a virtual drive.
Is there any reason to believe a burned copy would work better? I have disk1 mounted but the program insists its not there.
Turns out the answer was deplorably simple. By default, the game hard-codes into the system registry that its looking for the disk in the D:\ drive.
I feel bad for anyone who bought it back in the day and had dual CDrom drives or a second HDD.
So seems to work for now. Next I have to find a savegame editor and I'll be all set to go.
The game ended up effectively not being playable on the laptop. Which is kind of weird. The original Playstation was basically a 486. The PC port of the game only needed 233mhz(laptop was 300), and I recall playing this game flawlessly on a stupid 433mhz celleron with only 32mb of RAM back in the day. Ah well. Loading it up up an XP-era laptop.
The Playstation had a MIPS R3k CPU running at 33 MHz, which had considerably more horsepower than a similarly-clocked 486, and a matrix-math coprocessor and dedicated GPU on top of that. A Pentium II system should still beat it out, but not as handily as all that - plus, PC ports of Playstation games were frequently an afterthought, and I doubt there was much effort put into optimizing it.
