clh333
Yesterday I brought up the 586 AMD VLB that I had installed OS2 Warp 3 on some time ago. Apart from some hardware issues** the most annoying problem was the OS itself; I think I should upgrade to Warp 4. I see on WinWorld there are versions 4 and 4.52. Would I be advised to upgrade to 4 before installing 4.52, or can I go directly to 4.52?
Thanks for your replies
-CH-
**Award BIOS lost config due to backup battery low voltage, DTC SCSI controller was able to figure out the proper HD geometry, though. Video "wiggles" horizontally, slightly, especially during disk access. Could be the video card but I'll try substituting PSU first as failing caps are most likely possibility. Video also "drops out" (screen goes black) during certain refresh cycles. May be a lack of a driver, but I can't remember which card is in there.
-CH-
