Osborne Vixen Alive Again !!
codeman
Huntington Beach CA
I got this Osborne Vixen in a pile of Kaypro stuff , Was really hoping it was working but, this was all i got .
So i tore it all down and got out the scope and started looking around.
There are some schematics on archive.org but i believe there are for the prototype.
Chip numbers and pins used are different on this production unit.
But the basic design is the same .
Found out the 7406 in A7 was bad video going in and nothing coming out.
Once i replaced it .
Video looked great now just need to make a boot disk and see how it all works .
Also disassembled some of the bios and there are some IO routines in the 0xF0-0xFF range
and they are not internal to the Vixen so as a guess it would be for the Hard Drive .
ken
Congrats! Thanks for posting this. I have a Vixen that is very similar to this. I get the start up beep but the video is like your "before" photo. I don't have a scope but if I can find a 7406, I'll give it a shot.
Should have mentioned since the 7406 is a open collector part you can just piggy back them as a test to see if it works .
So you don't have to remove the chip and solder a new one in to test it .
ken
Finally got around to making a boot disk, looks like she works :)
And after using it for a bit seems like a very nice cp/m machine .
ken
Codeman,
Not only did you fix your vixen but you fixed mine too. It was the exact same IC that had messed up my video. Thank you! Now I just need to make the boot floppies to check screen alignment and close her up.
I've spent most of the day trying to get two questionable 5 1/4" floppy drives to work with no luck. Now I remember the frustration of working with PCs when you bought them a part at a time.
Anyway, thanks again and good luck on your auction.
That's great seems to be a fault in the design there .
Its a really nice computer good size and all .
that's why i put it at a high start price so if it don't sell i will keep it .
If you cant get a drive to work PM me your address and i can send you a copy of the disk set.
ken
I wonder if that affects the other clone of that system (Zenith .. um lol.. Z-171? (google.. woohoo! guessed right) and I thought there was one other also that used that same case/system but can't think of it right now. Ah ok, The Morrow Pivot.
Things do start getting hazy in the Osborne chronology so I just want to make a correction on your post. I don't believe the Osborne Vixen has a clone and it was made by Osborne. There also aren't too many around and actually is "rare".
As one of the sites on the Zenith Z-171/Morrow Pivot describes, this model was contracted out to Osborne as the Osborne Encore (Osborne 3) and was DOS based as was the Zenith Z-171 and Morrow Pivot. The Osborne Vixen is the Osborne 4 and is only CP/M. They don't look anything alike :)
Now I need to look for an Osborne Encore (Osborne 3) to fill in the set. <sarcastic>Thanks for that</sarcastic> ;)
Hi All;
I some years ago had an Osborne one or two can't remember which..
And so I never heard of a Vixen, Can You post a Picture of the whole machine, for comparison sake with what a one or two looked like ??
Of course I never heard of anything past the one or two.. I thought that was all they made..
THANK YOU Marty
Quick update from me:
I was able to make the Osborne Vixen disks finally. I spent a few hours wondering why these disks wouldn't work and recreating them over and over again. Tried to clean the drive heads manually but no luck. I then tried to line up the floppy hole with the hole in the media and determined that the drive wasn't spinning even though it sounded like it was doing something. I finally opened the floppy drives up and inspected drive A carefully and found a screw missing. When you put the floppy in twist the drive handle, there was a screw missing in the knuckle that would push down and clamp down the top head assembly. Once that was going, it worked like a charm.
It is a great machine.
