intabits
Having previously tested or repaired the power supplies, console interfaces and memory boards of my
PDP-11/04 and 11/34, it was time to try inserting the CPU boards into them.
Just before powering it on I noticed something on the 11/04's CPU board (M7263) that I had stupidly
neglected to look for much earlier.
Some general corrosion, but especially bad around E32, where it appears that a trace may have been
corroded away.
But after cleaning it up, and consulting the schematics, I'm 95% sure that it was a factory trace cut,
and therefore the corrosion was not quite as bad as previously feared, so I decided to power it up.
The Run light was stuck on, and I'd read that this could be the result of the NPG or BGx grant chains
being incomplete. While checking the NPG chain, I found a small broken part of the backplane
connector.
Unfortunately, it appears this break may have allowed -15v into the NPG out pin of the CPU.
So that put a halt to further testing of the 11/04 for now.
Turning my attention to the 11/34, I just plugged the power supply into the mains socket, which
resulted in sparks and melted power plug pins. So there was an obvious short circuit in the power
supply mains input. There were no issues last time it was used.
So ended my ambitious attempt to quickly get two working PDP-11's on the same day.
I'm also wondering if the far more experienced PDP-11 people can tell me if an '04 or '34 CPU should
be operable from the console with just the following: M7263/M8266+M8265, M7847, M7859 and M9302 (and G727A grant cards)?
Or is the M9301/M9312 (or anything else) also required?
Video:-
https://www.youtube.com/watch?v=OiGnCDZpN7I
corroded away.
connector.
Video:-
