m_thompson
We just started a PDP-11/40 project at the RICM. We got the system from Fairfield University who got it from yale University. Yale gutted the system and installed a hex-wide Q-bus backplane, 11/23 CPU, Memory, 4x Serial Ports, and GPIO cards. They even made a wire-wrap board to interface to the 11/23 CPU.
We need to repair a cooked connector on the power supply harness and on the power distribution backplane that feeds the first SLUs. We have two giant Unibus expansion chassis that we can use for parts to fix this chassis. We also need to add another +5 power supply when we populate the last slots in the chassis.
We have two complete sets of PDP-11/35 - PDP-11/40 CPU boards, backplanes, memory, serial ports, consoles, VT11, RL11, RX11, clocks, GPIO and other Unibus boards to go in this chassis.
We plan to set the system up to run all of the DEC operating systems by swapping RL02 packs, and to try running UNIX.
If we run into unsolvable road blocks with the 11/40 we have two PDP-11/45 systems that we could use to make a running 11/45. We even have a PDP-11/70, but no spares for it.
