MauriceH
Have a M8650-YA card that keeps having problems.
So far I mange to get a bit going.
Program 33 of the Toggle (Echo test 03/04) perfect, no problems, also when a Key is pressed continues there is no failure in the print out.
The AC is showing correctly the typed Char, f.i. A=0101. All tests with all kinds of Key's, char, as well as numbers , Capslock etc. they all print correctly.
The prog 32 (Char Print test) just rubbish as a print out, Also the AC does NOT increment, but shows the same rubbish.
The prog 31 (Print Char put in AC) does some correct, and a pattern of failure is to be seen.It repeats the pattern with the same failure.
Now I am trying to figure out and localise what part of the M8650 should be at failure.
-Think RX and TX buffers are OK
-All at the right side of Buffers (RX and TX) part must be ok due to at ECHO test the sent receive is correct.
-RX-TX Address selection paths are OK, as card reacts on control lines and ECHO prog is working.
-X-TAL is OK (even changed it out)
- RX-Decoder E43 had a failure and has been replaced by a 7442(conversion done)
Seems to be a kind of timing issue, or out of sync.
But why is it running ok with prog 33 Echo-test, when I keep pressing a key, and that keeps printing correctly.
Here what I get With prog 31 Print AC
Char "A"
This With Char "B"
This with Char "1"
This with Char "2"
This is the Char Print prog 33
Char "A"
This With Char "B"
This with Char "1"
This with Char "2"
