What can i do do repair this Dave?Yes, the UD6 pin 19 oval solder pad appears to not be shiny and bright where the track exits to UD7. Is there actually any copper there - and is it physically connected to the track that goes to UD7?
Ok thanks so much!Solder a piece of wire between pin 22 of UD6 and UD7 underneath the board once you have mounted two new sockets.
Ditto for pin 19 (and any other pins that have no connection).
Please (however) test ALL of the pins for conductivity between UD6 and UD7 NOW whilst the sockets are removed.
All pins should be wired between the sockets (apart for pin 20 which is the /CS pin) - i.e. UD6 pin 1 to UD7 pin 1, UD6 pin 2 to UD7 pin 2 and so on down to UD6 pin 24 to UD7 pin 24.
Look especially close at the oval pads that are not bright and shiny but dull and tarnished.
Ok thanks!Ok,
I would still like you to put the other ROMs back in (at least as a test) to see if they have the correct checksums.
I suspect your 'new' problem may be temperature related - so you need to let the PET cool down before running it again.
See if it is consistent in that if you start it up from cold it runs for a similar time before problems start to occur.
Have you got any freezer spray?
yes i have it!Have you got any freezer spray?
