Bagpuss
Hi, resurected my second PET how (bad A7 buffer and blown ROM). My first pet had to be a donor but it's getting a mini pet board now as the PCB was very poor.
But I am in the process of recovering a 4040 drive. I refurbished the disk drives and it did a proper under 3 seconds on led start up. I think though it's had a wobbler on me.
On my third power up it blew the fuse. I think it may be the RF filter has failed short as testing the on/off switch I get - On - near 0 ohms, off about 190 ohms. On the UK plug I also get 190 ohms L-N and open circuit in L-E and N-E which figures on blowing the fuse.
Removing the fuse and with the main switch off I still get 190ohms across the on/off switch so I think I am getting a short On the filter or transformer.
The filter is some whacky German thing with 2 blue wired and 2 black ones, no explanation of wiring.
I'll add pictures in my first update post.
I expect I can just cut the out but I get conflicting Google searches the it's blue input, black output Vs blue to blue & black to black (I suspect it's blue in black out from the wiring).
Now I have a second ratty 4040 as a donor but it looks like someone heath robinson'ed a repair but removing the RF filter, screw capped a connection and tucked a transformer wire out the way (which seems an odd thing to do).
So asking the hive mind here, are the RF filters like the old rifas, that let the burnt marshmallow smell out, nd just bypass it (and later get a replacement in there)?
I was thinking of pulling the whole transformer assembly from the donor but it looks a bit bodge repair to me.
