Bockmeister
- Joined
- Nov 14, 2025
- Messages
- 5
Has anyone ever seen this failure mode on a PET 9-inch display before? Before re-capping the display, it was immediately displaying the raster in a vertically squished area in the middle of the screen, but you could just make out the output.
After re-capping, as long as the power has been off for a while, it will display normally for about 5 seconds, then the green slowly fills the screen from top to bottom.
I do have an oscilloscope and the PDF of the schematic, but I was hoping someone might have an annotated diagram of the PCB with the TP's labeled.
BTW, the only cap that I haven't replaced is C28, the 10uF that from what I've read, seems like most people don't replace. Any insight would be greatly appreciated.
