Cloudschatze
Here are a couple of additional Tandy 1000 BIOS modifications, this time shifting the external boot ROM range that normally starts at CA80h in the RL, RLX-A/B, TL/2, and TL/3 systems to CA00h. By so doing, a card such as the PicoMEM can then be booted from that address, freeing-up the entire D000h-DFFFh range for EMS or UMBs.
The RLX modifications also include a VGA BIOS update, and, for the RLX-B specifically, the disabling of the internal ROM drive (as needed by both the PicoMEM and XUB-based cards).
You'll need a 27C400 or compatible EPROM (200ns or better) to write the relevant BIOS image to. If using a TL866 device, you'll also need an appropriate adapter. Take note of the position of the 40-pin ROM in its 42-pin socket before and after.
Tandy 1000 RL BIOS ROM Version 02.00.01
Original: 8079073.BIN
Modified: 8079073_CA00.BIN
Tandy 1000 RLX-A BIOS ROM Version 02.00.00
Original: 8049021.BIN
Modified: 8049021_CA00_VGA1-BIOS-VER-D-1.00-07.BIN
Tandy 1000 RLX-B BIOS ROM Version 02.00.00
Original: 8079074.BIN
Modified: 8079074_NOROMDRIVE_CA00_VGA1-BIOS-VER-D-1.00-07.BIN
Tandy 1000 TL/2 BIOS ROM Version 02.00.00
Original: 8079044.BIN
Modified: 8079044_CA00.BIN
Tandy 1000 TL/3 BIOS ROM Version 02.00.00
Original: 8079072.BIN
Modified: 8079072_CA00.BIN
- Allows booting from CA00h
- VGA BIOS Version D, 1.00.07
- Disables ROM drive
