ruthlessperson
Banned
- Joined
- Dec 6, 2009
- Messages
- 30
Hi all, I have a power supply from an 5150 and It won't stay on for then a few milli-sounds enough to slightly spin the fan, then it's dead. I have removed the power supply and tested it with known good system and with no system and with a load like and HDD still nothing so the fault is inside the power supply itself. I don't know if this means anything but I toke the voltage readings from the molex plug and the 5 volt jumped right up to the normal range however the 12 volt did not so well so I am thinking its in the 12 side of the supply unit. I have just a muilt-meter for testing so please try to give simple step by step help. Thanks and have a nice day.
Note the caps look good, no pop tops or anything like that, nothing looks burt or shorted.
