inotarobot
Bit of History.
Many here will recall I bought my Sirius 1 about 8 months or more, from a young man, whom is learning IT at school. He had bought it from a Flea market, but failed to get the SIRIUS 1 keyboard.
Recently I bought a second Sirius 1 with keyboard from a Gentleman in Adelaide, whom shipped me, via Australia Post, the Keyboard.
I have a separate thread here on how the parcel arrived.
Anyways not long after the keyboard arrived, I decided to open my Sirius 1 up.
Found the 0.33uF cap in the power supply had failed. Also the two 0.1uF caps in same mains AC input area were bulging.
Further investigation revealed they were in fact only rated for 250vac and the Mains here is 254vac.
So I sourced some nice higher rated ones, fitted them. Reflowed about 6 dry solder joints and then after connecting supply to my variable PSU load, powered it up on bench. All voltages were in close to correct.
I found that issues with the 8087 heat sink, that I started a new thread here. As yet I have not refitted heatsink.
Finally today I decided to reassemble the machine and give it a short run, to see what it does.
BTW my machine has 1 floppy drive and one hard drive.
I had tried to power it up not long after I got it, and got a few symbols on the lower part of screen.
One indicated to put a floppy in. However I had no floppies with it, so that was a no go.
I initially assumed since it did not boot from the hard drive that just maybe the drive had been 'wiped' by original owner.
Fast forward to today 30th June 2017
I put power to the machine
Got the screen showing 128k on the bottom and a symbol of floppy with an up arrow alongside it.
So I got out the floppies I bought at same time as Keyboard
Tried a few of the system Disks. NO boot
So off to have some dinner and sleep
