PS/2 Model 30 8086
BillT356
Barnegat, NJ
I have an IBM PS/2 Model 30 8530-002, system unit only.
Specs:
XT 8086, 8.0 Mhz
640 KB RAM
2 3.5" 750 KB FDDs
I have checked out this unit with a copy of the start-up disk, everything works fine. The "B" drive make some noise at first, but then quites down.
Make offer + shipping from 08005. If no offers from here, then it goes on
e-bay
Specs:
XT 8086, 8.0 Mhz
640 KB RAM
2 3.5" 750 KB FDDs
e-bay
what are you asking for this? i may be interested. does it have ISA slots?
...does it have ISA slots?
Normally three (3) 8-bit slots (along with a battery for the RTC) on a riser...
This system has the two (720Kb) floppies, so probably no HDD (there would not be an available bay)...
"MCGA" (a limited VGA) video, floppy controller, HDD (proprietary) controller, COM (8250 UART) port, LPT (bi-directional) port, & RTC on the system planar...
8086-8MHz...
640Kb with two proprietary 256Kb SIMMs and 128Kb soldered on the planar...
8086-8MHz...
Wasn't MCGA something like 320x200 @ 256 colors and 640x480 mono?
I believe it supports all CGA modes, but not sure about EGA 640x350 @ 16 colors.
Wasn't the Model 30 8086 the same internals (different board layout) as the all-in-one Model 25's?
Man I used to know all of this... Been disconnected from "beige and blue" for a while now. :(
Yes, kind of a "VGA, without EGA" (and only 64Kb VRAM). The Model 30 based on the 8086 CPU was an identically-functioning (different planars) as the 8086-based Model 25, but also added an RTC. For the 286 level, there were two different planars for the Model 25 286 and Model 30 286 that were equally shared between the units.
PS/2 Model 30 8086
The bathroom scale (not legal for trade) shows it weights 10 lbs. with out any packing.
The Model 30 came before the 25 in the 8086 variety. It would be better to say the 25 lost the RTC functionality
I never meant to imply that the Model 25 came out before the Model 30 by the statement, but instead I was referring to the features that are different between the units...
Hello all, I recently picked up a IBM PS/2 Model 30. I own 2 IBM PS/2 Model 30 286's and I was surprised to find that the 8086 version is a lot different. The starter disk doesn't allow you to configure the system at all. It only allows for setting date and time. I am trying to add external floppy drive but don't see how I am supposed to specify this. On my 30-286 I setup like a normal drive in the BIOS. I added the card and drive hoping it would auto-detect it or something. It did not.
Maybe I have to specify as an external drive via DOS such as I do on my IBM PC/XT's? I am going to try that next. Appreciate any information on this subject if somebody knows. Thanks!
Okay, I figured this out. I had a defective ribbon cable. I repaired and it now works. I am using the IBM 72X6757 (90X8827) external drive adapter card with the IBM 4869-01 in IBM Model 30 8086. There is no BIOS configuration needed, it automatically sets it up as drive B.
