| VCF SoCal | Feb TBD, 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
| VCF Latam | TBD, 2027, | Bahía Blanca, Argentina |
| VCF Pac. NW | TBD , 2027, | Tukwila, WA |
| VCF Southwest | Jun 25 - 27, 2027, | Westin Dallas Fort Worth Airport |
| VCF Southeast | Aug TBD, 2027, | Atlanta, GA |
| VCF West | Aug TBD, 2027, | Mountain View, CA |
I suspect it's capacitor related but the PSUs are tight and extremely complex. Multiple daughterboards with control circuitry. It's a pity.
What is the maximum interval that I can store these electronics with minimum risk of failure?
How long is a piece of string...What is the maximum interval that I can store these electronics with minimum risk of failure?
A number of IC's in storage foam did this because some of the early foams were Latex based and it contains Halides as a contaminant, that attacked the silver plating on the steel pins of the TI brand IC. Once the Silver plating fails, then the rust sets in. The silver plating also gets wiped out by atmospheric Hydrogen Sulphide (H2S), which in some places is very high level. Probably the worst place is Hell's Gate in Rotorua NZ.
One interesting thing about Tin whisker faults, they can cause unique types of scenario where two circuits that are normally independent interact.Tin Whiskers deserve an explicit mention as a potential failure mode as well.
It is impossible. Eventually, oxygen will eat everything. Gold plating has a long life span but even that is not immune.Electronic devices have been on the market for several decades and to this day they have not been able to create a corrosion-resistant metal or protection on PCBs and components.
