QX-11 ROM Options.
vprada
Miami, U.S.A
An article I read about the QC-11, the Japanese version of the QX-11, stated that the QC-11 came with 128KB of ROM. The export QX-11, however, comes with two 32KB ROM chips, for a total of 64KB of ROM.
While doing some reverse engineering around one of the gate arrays installed in the QX-11, I found a set of jumpers labeled J1, J2, and J3. I discovered that these three jumpers allow you to change the expected size of each of the QX-11 ROM chips. Based on what I found, the machine can support 16KB, 32KB, or 64KB ROM chips.
Changing the jumper positions changes how the address lines for each 27256 ROM chip are connected. Position B on each jumper ties the corresponding 27256 address line to 5V. Position A ties the ROM address line to the system address lines A14 or A15.
Having the option to install a 64KB ROM allowed me to add additional utilities that are available immediately at boot time. These utilities have proven to be very useful, especially when restoring a QX-11 without any QX-11-formatted disks, or when there is no easy way to create new floppies from disk images.
I created a detailed post in my QX-11 github but long story short, my new rom includes FORMAT.COM, FILINK.COM and MODE.COM, to basically format new floppies with the native QX-11 format, transfer files from a modern system to the QX-11 via serial port, and mode to change the default speed for the serial port.
Adding another discovery to this, there is an additional jumper labeled as J4 that let you choose what kind of DRAM chips you can use. In the particular case for this jumper, position A will set the address line to use 50256 DRAM chips. When the jumper is on position B set the machine to accept 4064 DRAM chips.
