geoffm3
I just got one of these buggers from a (semi-) local seller on eBay. It is fully loaded with RAM (I believe 3MB?) Anyways, it seems to work fine in 24-bit mode but I can't tell if it's actually accelerating the graphics at all. According to all documentation I can find online this is supposed to be a Quickdraw accelerated card, however when I open the QuickColor control panel to enable acceleration (as I've learned is required in order to support it), it has a pane above the acceleration enable/disable button that is supposed to show all the acceleration-capable cards and there are none listed.
I haven't run any sort of benchmarks yet but that struck me as odd. It does seem like things are slightly more fast when enabled vs not in things like scrolling up and down through a long list of pull down menu options for example.
Is this correct behavior in this control panel? I'm running v3.3.
