MikeS
It makes sense but doesn't help much. What voltage do you measure across the outside terminals of the brightness control (that should be easy to get at); you should have about 30V.Hi Mike,
I took that measure by controlling the output tension on the big power supply close to the mainboard. Does it make sense ?
I managed to get for a a few days a working PET at home ; so I can compare tensions on both machines if it can help ...
Stéphane.
Can you access the three terminals of the 7812 regulator in the heatsink? Between the middle terminal and the outside terminals you should have 16.5V on one side and 12V on the other.
Be careful that you don't accidentally short anything with the meter probes.
