Hi everyone!
I am setting up a new (old) microPDP-11 in a BA23 chassis with a bunch of various cards and parts I have purchased.
I was able to obtain an RD52 drive that appears to be functioning and readable. Unfortunately it was originally formatted with an RQDX2, but I have an RQDX3 so I obviously get an error when trying to load it through the PDP due to the formatting differences.
I am hesitant to reformat this drive to work with my unit without knowing its contents...as it might have something on it worth saving and making publicly available.
I do have David Gesswein's MFM emulator and was able to get a (mostly) successful image of the drive.
is there a way to convert this to a readable image by an RQDX3, or otherwise emulate it so that we can see the contents?
root@beaglebone:~/mfm# ./mfm_read --analyze --transitions_file raw_data --extracted_data_file extracted_data --note "RD52 raw read"
Board revision C detected
Found drive at select 3
Drive RPM 3527.6
Found matching format RQDX2: good count difference 0
Interleave mismatch previous entry 0, 9 was 1 now 0
Selected head 8 found 0, last good head found 7
Read errors trying to determine sector numbering, results may be in error
Number of heads 8 number of sectors 18 first sector 0
Unable to determine interleave. Interleave value is not required
Drive supports buffered seeks (ST412)
Disk has recalibrated to track 0
Stopping end of disk search due to recalibration
Number of cylinders 512, 37.7 MB
Command line to read disk:
--format RQDX2 --sectors 18,0 --heads 8 --cylinders 512 --header_crc 0xffff,0x1021,16,0 --data_crc 0xffff,0x1021,16,0 --sector_length 512 --retries 50,4 --drive 3
Retries failed cyl 252 head 1
Bad sectors on cylinder 252 head 1: 1
All sectors recovered after 2 retries cyl 481 head 7
Retries failed cyl 511 head 0
Bad sectors on cylinder 511 head 0: 16H 17H
Retries failed cyl 511 head 1
Bad sectors on cylinder 511 head 1: 16H 17H
Retries failed cyl 511 head 2
Bad sectors on cylinder 511 head 2: 16H 17H
Retries failed cyl 511 head 3
Bad sectors on cylinder 511 head 3: 16H 17H
Retries failed cyl 511 head 4
Bad sectors on cylinder 511 head 4: 16H 17H
Retries failed cyl 511 head 5
Bad sectors on cylinder 511 head 5: 16H 17H
Retries failed cyl 511 head 6
Bad sectors on cylinder 511 head 6: 16H 17H
Retries failed cyl 511 head 7
Bad sectors on cylinder 511 head 7: 16H 17H
Found cyl 0 to 511, head 0 to 7, sector 0 to 17
Expected 73728 sectors got 73711 good sectors, 16 bad header, 1 bad data
0 sectors marked bad or spare
0 sectors corrected with ECC. Max bits in burst corrected 0
Track read time in ms min 29.864625 max 3211.182709 avg 43.738691
Drive RPM 3527.6
